HP Laserjet M1319F Laser Multifunction Printer Logo
Anonymous Posted on Jan 19, 2010
Sending fax HP 1319MFP while some faxes are being sent, a new fax can not be sent until all the previous faxes are gone.... pls explain what to do
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
270
Points
Anytime i send a fax, all that i get is NO FAX
Anonymous
Level 1:
New Friend:
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
270
Points
0
FIXED WITH THE HELP OF HP GUY BY UPGRADING THE SOFTWARE IN TO THE MACHINE.
3helpful
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
4helpful
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
3helpful
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
1helpful
HP 640 fax won't send fax but phone works
Unfortunately wer purchased two new hp office jet 7610 which do not come with cabling and we could not get the fax to work. I spent 3 days on the telephone with hp and British Telecom each of which blamed it on each other. After doing some research on the internet I discovered that hp require a strange cable formant which is called a 'cross-over cable' is required. I bought them from cabling4less.co.uk and the product code is BT-203X. They can be found on their web site www.cabling4less.co.uk The link is: http://www.cabling4less.co.uk/category.php?cat_id=237 This should resolve this frustrating problem.
1helpful
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
1helpful
Need confirmation of fax sent and received
You can setup the printer to print a confirmation page on send. Push the setup button - then push right arrow until you see print report and press okay - press right arrow until you see fax confirmation and press ok - push right until it says on send and press ok. Hit cancel to go back to default and now you will get a confirmation for all sent faxes.
2answers
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
4helpful
4answers
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
24helpful
Fax Confirmation Sheet
k24674
Grand Canyon Tech
Grand Canyon Tech
