When trying to scan documents using Capture Perfect 3.0, I receive this error message.
Capture Perfect 3.0
Scanner command invalid in current state. Canon DR-6080/7580/9080c Driver v 1.3.10502.17001 (-4438)
I also installed Capture Perfect 3.0 upgrade but got the same error message. What can be done to fix?
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Same thing, if you select count only the paper will feed
capture perfect
