Olympus FE-280 Digital Camera Logo
Posted on Dec 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to replace the rear view screen on my camera. I have the parts, just need to find the info on how to do it. Is there a blue print of how to?
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Dec 11, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2201054
Points
38521
Google the words...disassemble a digital camera.
1helpful
Back up camera on 2012 f150 4x4
The blue screen indicates no signal from the back up camera.
LCD screen blinking Canon Rebel Xt
The bottom right screw on the rear circuit board comes out in this model (over 50 % of the time). Remove the rear cover (ground yourself!) - two black screws on side, three on bottom, two inside when you open the CF card door. Gently pull out the rear cover - CAREFUL, it is attached to the main circuit by two flexes. Check and see if the screw is shorting out the flex connector for the LCD. Retrieve and reinstall screw, and hope it hasn't shorted out part of the main circuit.
Remove the battery before you take apart the camera!!!
1helpful
Getting a blue screen from rear view camera, worked fine until today
Blue screen is generally no signal from camera, possibly broken camera feed wiring or bad connection, if the camera is on a tailgate, breaks occur where the wiring leaves the tailgate to th car body, good luck.
1helpful
Problem is only with snapping the picture. The screen started out being blurred only AFTER the photo was taken. Now the entire screen is black (no image) after the photo is taken. It just started the...
It is known problem of ccd imager chip failure in DSC-T1 camera, ccd imager chip will be replace to get correct live view in camera mode to take fresh pictures.
Local camera repair shop will do this job because camera will take apart, let me know to provide you part number info if you are handy with electronics stuff repair and willing to replace ccd imager chip.
Hope this will help.
Thanks.
2helpful
The problem is everytime i turn my head lights on the pyle swiches to a blue screen, the radio goes off and it has the words "car" in the top left corner of the blue screen. i own a 2004 ford...
you have your wiring wrong, im guessing you have a rear view camera on there, you need to dissconnect the wire thats for the rear view camera (behind ur dvd) get another wire , connect one end to your backup lights (12v, red) and connect the other one to the wire for the camera behind ur dvd player
1helpful
2answers
Every thing seems to work but view screen is blue and takes a blue picture (has ripples that move when you point or move camera around like you can almost see something but you can't. My logo and phone...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
No image
Rear camera issue.
Check conection to camera.
Negative effect screen
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Lumix DMC-FZ7
The rear screen can be replaced. Unfortunately Panasonic specifically charges so much for their replacement parts that it is not an economical repair on this model of camera. The replacement screen will run in the range of $125-$145 and the labor to install it will be about $50 depending on where you go.
You are best advised to get a new camera, although because this one still "works" you can still use it as a back up!
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
