20 Most Recent Olympus FE-240 Digital Camera Questions & Answers
Al prender mi camara digital
When this problem occurs Protec. Escr., Just enter the tools menu and find "Format" and voila, the camera returned to work usually remains
1/15/2018 9:16:48 AM • Olympus FE-240... • Answered on Jan 15, 2018
2answers
My Olympus fall on the rock, but it's seems no trouble, after 3 month, the LCD going vibrate, and LCD going not clear, need your sugestion sir, to repair, thank you
The Olympus FE-240 Digital Camera is a cheap model. For what it would cost to repair it, you could buy a good Cannon
5/20/2014 5:16:45 AM • Olympus FE-240... • Answered on May 20, 2014
I cannot transfer my pics
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
11/13/2013 9:57:57 PM • Olympus FE-240... • Answered on Nov 13, 2013
How to Use
11/13/2013 9:56:57 PM • Olympus FE-240... • Answered on Nov 13, 2013
Manual for Olympus Fe-240
Did you try this link?Download olympus user manual FE-240Last time I tried ( 5 minutes ago) it still worked.
11/13/2013 8:49:36 PM • Olympus FE-240... • Answered on Nov 13, 2013
Message on my screen: couver carte. It is a new
"Couver Carte" is french for basically, SD Card cover is open. Your first problem is that the camera is setup to language "French" and by using the menus in setup, of the icons if displayed, you can change the setting to "English"You can attempt to take it to a repair shop or disassemble the camera yourself, either way there are reports that a small lever might be broken. This lever presses a button that then sends a signal to the camera to let it know that the card cover is closed and is ready for use. Personally, I would let the techinician attempt to fix it or purchase a new camera, as I have seen a lot of complaints for this brand on this simular topic
8/25/2013 2:46:17 PM • Olympus FE-240... • Answered on Aug 25, 2013
3answers
Protec. Escr. ¿qué significa esto?
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
8/20/2013 4:22:18 AM • Olympus FE-240... • Answered on Aug 20, 2013
manual
2answers
Driver
Please try here.
Brian
3/17/2013 6:15:49 PM • Olympus FE-240... • Answered on Mar 17, 2013
Can't connect to computer. it's
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
6/25/2011 12:56:10 AM • Olympus FE-240... • Answered on Jun 25, 2011
Buenos dias tengo un problema
Desde el menú de la cámara formatea la memoria.
Si no funciona, formatéala desde la PC.
Si no se formatea en una PC, la memoria está defectuosa. Compra otra.
6/20/2011 7:43:49 AM • Olympus FE-240... • Answered on Jun 20, 2011
Need down load driver
You can download the software here:
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1284
Just choose your platform of your computer and you should be on your way.
Cheers!
4/19/2011 5:30:15 AM • Olympus FE-240... • Answered on Apr 19, 2011
I have a window7 notebook
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
1/19/2011 10:17:01 PM • Olympus FE-240... • Answered on Jan 19, 2011
The cover on the battery
I imagine the only way to obtain a proper part is to send it to an approved Olympus service centre, hopefully under warranty (though I expect they would not regard this as covered).
The camera must have some way of telling that the door is open. Is there a tiny switch on the catch, or behind a little hole that something on the lid poked through? If so, perhaps you could jam it. Maybe there is a reed switch that was activated by a magnet in the lid.
I don't really see why this should be an issue for the camera to worry about, as long as things aren't falling out. My high-end Lumix pays no attention to hatches being open.
11/3/2010 5:35:43 PM • Olympus FE-240... • Answered on Nov 03, 2010
When I switch on my
So, did you go there for help?
10/14/2010 8:50:44 PM • Olympus FE-240... • Answered on Oct 14, 2010
Olympus FE-240 Digital Camera Logo
39 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
FE Olympus
  • FE Olympus
Most Popular Question
al prender mi camara digital
  • Cameras
