I cannot get a laptop on a client's network to Fax to an HP 6310A-I-O printer. One PC on the network faxes fine and the other cannot, it can print, and all other functions work, but faxing from this PC does not work.
When I look at the Event Viewer-Application I get the following two errors:
Event Type: Warning
Event Source: Microsoft Fax
Event Category: Initialization/Termination
Event ID: 32068
Date: 2/24/2006
Time: 8:43:47 AM
User: N/A
Computer:
Description:
The outgoing routing rule is not valid because it cannot find a valid device. The outgoing faxes that use this rule will not be routed. Verify that the targeted device or devices (if routed to a group of devices) is connected and installed correctly, and turned on. If routed to a group, verify that the group is configured correctly. Country/region code: '*' Area code: '*'
For more information, see Help and Support Center athttp://go.microsoft.com/fwlink/events.asp.
Event Type: Warning
Event ID: 32026
Date: 2/24/2006
Time: 8:43:47 AM
User: N/A
Computer:
Description:
Fax Service failed to initialize any assigned fax devices (virtual or TAPI). No faxes can be sent or received until a fax device is installed.
There is no modem installed, I've uninstalled the drivers and software and reinstalled. No dice. I've stuck and don't know where to go next. Anyone have a problem like this before?
SOURCE: HP L7680 All in one will not send faxes from PC S/W interface
did u try to download ther latest software all idrect form site dont use cd
SOURCE: Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is
plugged directly from the wall jack into the back port of the fax
machine that is marked "Line" or "To Wall Jack", or that has a
wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line
such as splitters, credit card machines, or telephone answering
machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
SOURCE: i can not receive fax
Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code.
Regards, Riztech
Regards,
Riztech
If you need more help come back.Post /
thumbs / testimonial are
welcome!
