You need to either replace the cable or the lcd itself.you can try reseating the cable which is attached to the lcd itself or the inverter cable which resides at the base of the lcd.
good luck
The LCD is going bad, the replacement cost is about 200$ a ballpark figure keep in mind, first bring it to a repair shop and get a estimate, i usually don't charge for this. But this will depends on that specific shop that you bring it to. Good luck.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
