Do the normal connect process , the on the pc go to the xerox site and down load the driver for your model from there , install it and the printer will see the pc and work
I am assuming you are using the document feeder, either way, usually found through the options one the menu once you select the copy tab. Select all the options you want applied to this particular job and then copy. If you wish for them to be permanent please go to Xerox's website and download the applicable manual - usually the system administrator's manual.
Xerox support for this model is located: http://www.support.xerox.com/support/workcentre-5865-5875-5890/documentation/enus.html
As far as I know you need either the Xerox Accxes controller (like a dedicated PC) or a wide-format printer with the built-in Accxes controller, like the Xerox 8825 model. The 8825 has the firewire input and communicates just fine with the YWC-1.
You can download the Xerox scanner drivers from theirsupport WEB site. Please click on this link and select your model scanner todownload :-http://www.support.xerox.com/support/enus.html
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
