Terri Mashburn Posted on Dec 31, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Canon mg2522 is having problems with feeding the paper into the printer!
Lenin Hudiel
Level 3:
Master:
  • Canon Master 934 Answers
  • Posted on Jan 15, 2020
Lenin Hudiel
Canon Master
Level 3:
Master:
Answers
934
Questions
0
Helped
508487
Points
7817
Disconnect the printer and turn it upside down. And shake it a few times Maybe there is a foreign object in the paper path
Carolyn Shields
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 04, 2022
Carolyn Shields
Contributor
Level 1:
Answers
Questions
0
Helped
3221
Points
I have a MG2522 Canon printer and the paper will not feed thru the machine. While reading other comments I turned my printer upside down and gave it a shook and it still does not work. It is a brand new machine and after I turned it upside down nothing fell out. How can I get it working?
5 Related Answers
Anonymous
  • 24 Answers
  • Posted on Jan 22, 2008
SOURCE: canon ip90 printer
The printer should be on,remove the paper from the printer(if there is any),press and hold the down arrow/cancel button, release the button when the power light blinks 3 times ... The printer will rollers will automatically revolce and clear all the jams.. When the power light is green then repeat the same step 3-4 times.. To confirm the paper jam is cleared then feed 8 1/2 * 11 paper in the printer and again press the down arrow button and release the button once the power light bliks for 3 times and then release the button. If the printer feeds properly it confirms the hardware of the printer is fine.
Software issue: Go to printer and faxes in computer and check the icon. If it says.. 0 paper jam then, delete the icon and chcek in the device manager if there is an entry of usb printing support under Universal Serial Bus controller .. if the entry is there then delete it. Insert the printer cd in the computer and unplug and replug the usb cable from the printer. If the setup screen comes up then exit out of it and the printer drivers will get updated. After that tried to print another tets page from the computer. It will definately print. Thank you.
Anonymous
  • Posted on May 22, 2008
SOURCE: Canon Pixma MP160 paper will not feed
try the feed button which is usually on the front of the machine. press once
Paul Blum
  • 6 Answers
  • Posted on Jun 12, 2008
SOURCE: Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
Anonymous
  • Posted on Feb 08, 2009
SOURCE: Canon MP600 paper wont feed- error message- HELP!
Right ... After 5 minutes of looking and fiddling I have found the solution!! press the button abover HOME and it should change the tray in which you are printing from :D
Problem solved
Anonymous
  • Posted on Nov 10, 2009
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
2answers
How do I connect a Canon Pixma MG2522 in a MacBook?
The functioning of your Mac Book is a little different from Windows. It is possible that this may get you confused. Let's take a look at the steps for how to connect Canon Pixma MG2522 setup in Mac. Click on 'Drivers and software' options in your printer and chose the version of Mac OS you are currently using. Start downloading the printer driver on Mac. Then, double click the downloaded file to run it. Now, you have to select the 'Continue' button twice. Thereafter, press 'Install' to add the Canon Printer to your Mac Book.
https://connectmyprinter.com/how-to-setup-canon-pixma-mg2522/
How to Set up Canon Pixma MG2522 in Mac Book?
The functioning of your Mac Book is a little different from Windows. It is possible that this may get you confused. Let's take a look at the steps for Canon Pixma MG2522 setup in Mac. Click on 'Drivers and software' options in your printer and chose the version of Mac OS you are currently using. Start downloading the printer driver on Mac. Then, double click the downloaded file to run it. Now, you have to select the 'Continue' button twice. Thereafter, press 'Install' to add the Canon Printer to your Mac Book.
4answers
Canon Pixma MG2522 Setup for Windows 10?
The vast majority of Canon printers are compatible with Windows 10. You can visit the official Canon website and check from there by entering the printer category, model name and then drivers and software to know if your printer is compatible with Windows 10. Canon Pixma MG2522 setup Windows 10 is a simple process. First, make sure that your printer is connected to a wireless network. Go to control panel and click on devices and printers, then select Add a printer. Select the printer and click Next. The printer would install automatically and then click on Finish to complete the process. https://connectmyprinter.com/how-to-setup-canon-pixma-mg2522/
3answers
How do I setup my Canon Pixma MG2522 with my router?
QuickBooks EnteRprise SUpPoRt nUMber 1[+1.888.547.2184] $!%*+ UsA
QUICKBOOKS eNterPrise ErRoR SuppoRt Phone Number 1[+1.888.547.2184], Get High End Resolutin of all QuickBooks EnterPrIse issue however professional counsels master. QuickBooks Error bolster Number @ [+1.888.547.2184] PRovide an exhaustive Financial arrangement, where it keeps all your business #bookkeeping5$ necessities in a *^single spot. From evaluations to bank moves, invoicing to following your costs and remaining over #QuickBooks bolster Number @ [+1.888.547.2184] with regards to assessment time, it is set up for every last bit of it at one go. A total bundle to liberate you from monetary bookkeeping and back office stresses whenever so you center around your very own master territory and yield potential development in business.dial @QuickBooks suPPort Number @+1.888.547.2184 . QuickBooks suPPort Number @@ +1.888.547.2184 #which is number one evaluated independent company [Quibooks] programming, is viewed as the mainstay of Intuit's private venture item system.QUICKbooks offers various item and administrations that go route past financials. These item and administrations caters little scale business focuses to oversee and showcase their work zone and furthermore guarantee achievement, at that point some other accessible monetary services.QuickBooks offer s specialized arrangement at QuickBOOKs @@ help ## Number [+1.888.547.2184]
Can I print from my phone with OTG cable on Canon to 2522
The Canon Pixma MG2522 printer's USB cable can not be connected with the phone. it can only be connected with computers. So, you can not print with OTG of your phone. You can print your document from computer with USB cable.
Need help setting up my Canon PIXMA MG2522
Steps to setup Canon Pixma MG2522
1. Watch that the machine is turned on
2. Burden paper on the machine
3. Open the printer driver arrangement window
4. Select an every now and again utilized profile
In Commonly Used Settings on the Quick Setup tab, select a printing profile appropriate for the reason.
At the point when you select a printing profile, the Additional Features, Media Type, and Printer Paper Size settings are consequently changed to the qualities that were preset.
5. Select the print quality
For Print Quality, select High, Standard, or Draft as indicated by your motivation.
6. Complete the arrangement
Click OK.
At the point when you execute print, the archive is printed with settings that match your motivation.
4answers
PIXMA MG2522 scanning,n printing doesn't have button's for either
Manuals for Windows or Mac. https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mg-series/pixma-mg2522/pixma-mg2522?tab=manuals
Canon Bubble Jet printer won't feed paper and print properly.
Hello sir; You need to clean up paper pick up roller and feed roller with alcohol, if still have problem then replace it.
old marine
old marine
ZJ Limited
ZJ Limited
