SOURCE: Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
SOURCE: We have an error code
I would suggest you replace this machine because the problem is very common with this machine. Unfortunately, there is no information on the code, just as you already know. The only error code info for this machine is error that starts with X, but there is non for L errors.
But before you conclude on replacing the machine, this is what you will have to consider.
Ascertain the cost of fixing this machine, then compare it the cost of getting another one. The price difference would determine whether it is worth repairing or not. I hope you understand what I mean.
Regards.
Error Description: Engine Logic Board Failure, Code 80
Possible Solution:
1. Cycle power to the printer to clear the error.
2. Did this clear the error? If, yes problem resolved , if no, replace the engine control board , or,
The image processor board
eng log brd part # required, 160K85653 cost approximate $125
proc brd 650-4306-00 aproximate cost $160
hope this helps -- please send me 4 thumbs up
