Here is a link to the User Guide (http://download.support.xerox.com/pub/docs/Phaser_3117/userdocs/any-os/en_GB/Guide.pdf)
Chapter 1 shows the meaning of the Control Panel lights. One green light lit sounds like normal operation. You must connect a USB cable to the computer and download/install the printer driver
https://www.support.xerox.com/support/phaser-3117/
SOURCE: my printer any time on red light please tell me reparing my print
Problem on fuser unite.When it hole surface block waste toner then arise this problem.Clean all surface and wast toner then solve your problem.
SOURCE: xerox phaser 3117 printer driver
Click here to download the drivers for Zerox Phaser 3117 from Xerox Official Support Site. Select the Operating Sytem and download the drivers fro free.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
SOURCE: xerox phaser 3117 printer not
You can find the driver for your printer and operating system here.
Download the appropriate driver matching your operating system.
Connect your printer to your PC.
Turn on the power.
Windows should look for the driver for the new device; if it can not find be prepared to point to the folder where you downloaded the driver.
SOURCE: from which site i install
You can install your printer from this site, http://www.support.xerox.com/support/phaser-3117/downloads/enza.html.
An installation guide as well the software are given here.
It should be everything you need to aid your printer installation.
Ifthis answer helpful please vote me.
Goodluck.
Thanksfor using FixYa
