20 Most Recent
Xerox WorkCentre 7132 PCL 6 Questions & Answers
Fault code 116-324 what can i do to fix this
116-324 System Controller RAP
An exceptional Controller error shut down the processor.
Initial Actions
Power Off/On
Procedure
Pull out and insert or replace the DIMM (PL 11.2).
If the problem persists, replace the ESS PWB (PL 11.2).
116-325 ESS Fan RAP
The ESS fan failed.
Procedure
Replace the ESS fan (PL 11.2).
Printing dulipcates on xerox 7132 when multi printing
In this case what i would Request u to do is. Goto Control Panel goto Printers folder. There u will see the Printer Icon. Just right click on the Printer Icon and click on Properties.Now click on Advanced and goto Print Processor.Change it to Printer Name and Win print Raw.Click on Apply click ok now try to Print.Good Luck!!!!
HOW TO RESET FORGOTTEN PASSWORN ON A XEROX 7435
If the default username and password (admin/1111) are not working on your Xerox 7435 printer, you can try resetting the password to its default settings using the following steps:
Turn on the printer and wait for it to boot up completely.
Press the button with a wrench icon on the printer's control panel to enter the settings menu.
Use the arrow keys to navigate to the "Security" option and press the OK button.
Select the "User Authentication" option and press OK.
Enter the current password, if you remember it. If you don't remember it, leave it blank.
Select the "Reset User Accounts" option and press OK.
Select the "Restore Defaults" option and press OK.
Confirm that you want to restore the default settings by selecting "Yes" and pressing OK.
After you have completed these steps, the printer's password will be reset to the default settings (admin/1111). You should now be able to log in to the printer's settings menu using these credentials.
Xerox Workcentre 7535 LED's flashing repeatedly when powering up
Hai this is Arun. If your motherboard gets power but the computer not starting then there are two solutions :
- Unplug the wire that is coming from the power switch to the motherboard & plug it again.
- If it is still not starting, then remove your CMOS battery and insert it again in the motherboard.
Hope these steps may solve your problem.
Thanks.
XEROX PRINTER CUSTOMER SERVICE {18OO*scammer69} pHoNe NuMbEr ==
FixYa Experts: Once you have reached a certain number of answers, then you can Edit and Delete these spam posts too, so they don't victimize unwary users. By my estimate, 4 of your fellow volunteer Experts are currently deleting 2500 spams per day, and it's not keeping up with the flood. Please help us out.
XEROX PRINTER CUSTOMER CARE {18OO*scammer69} pHoNe NuMbEr ==
XEROX PRINTER CUSTOMER SUPPORT {18OO*scammer69} pHoNe NuMbEr ==
