20 Most Recent Xerox DocuColor 242-252-260 PS Questions & Answers
2answers
Fault 010-321 what does it mean
010-321 Fuser nip fail, usually after repair fuser unit, commonly we accidentally spoil the nip sensor.
1/5/2020 10:47:09 AM • Xerox DocuColor... • Answered on Jan 05, 2020
Xerox Dc252 Error code 116-331, failing to load
HD fail
10/22/2018 10:39:13 PM • Xerox DocuColor... • Answered on Oct 22, 2018
I am getting a 'disk full' message on the Fiery. How do I delete it?
TROUBLESHOOTING This chapter provides troubleshooting tips. Troubleshooting the Fiery Startup diagnostics are described in the documentation for service technicians. Contact your authorized service/support center if you see error messages while Command WorkStation is starting or if the Fiery does not reach the Idle state. Runtime error messages For error messages related to canceling jobs and printing, including the Disk Full message and alerts to load media, see Command WorkStation Help. For error messages related to the copier, see the documentation that accompanies your copier. You can turn on PostScript error reporting as a print option from Mac OS applications. Printer not found Most failures to find a printer on the network are due to conflicting or missing name or address settings for the Fiery. You must type names in specific places. The required names are: •TCP/IP host name (also known as the DNS name), which is defined by your organization. Type the host name as the Server Name in Fiery Setup. •Remote printer (internal machine) name. Use one of the following: print hold direct NOTE: If you change the DNS name (also known as the TCP/IP host name) of the Fiery, you must reconfigure one of the utilities on each workstation. http://swdownload.efi.com/ftpvefigs/9019710383/2822679259/9432346727/7795362481/Configuration.pdf
12/22/2017 7:53:02 PM • Xerox DocuColor... • Answered on Dec 22, 2017
Xerox problems
12/22/2017 4:36:43 PM • Xerox DocuColor... • Answered on Dec 22, 2017
Can you adjust the fold position on a Xerox Docucolor?
The only way I know is to tell the machine to trim off 1/8 more of the cutting edge. This is none in the driver itself not the machine.
12/22/2017 3:45:14 PM • Xerox DocuColor... • Answered on Dec 22, 2017
I have a 094-321 fault i my machine what can i do please
Please do not keep re-posting, you can use the comment section.
12/22/2016 10:22:34 AM • Xerox DocuColor... • Answered on Dec 22, 2016
Fiery download message: Not able to save document
Fiery Webtools will not allow download
12/15/2016 8:51:48 PM • Xerox DocuColor... • Answered on Dec 15, 2016
Its appears repeatly error code 042-326 how to solve
Try clean the silver tape at back of the IBT Belt.
8/30/2016 1:08:31 AM • Xerox DocuColor... • Answered on Aug 30, 2016
Dc 252 is showing error code 062-380
This may be the error code for the piece that reads the image, i. e. the Lens CCD aka Charge Coupled Device. This is a light sensitive integrated circuit, i. e. a sensor. If the sensor has failed, you can't scan. That looks like a repair or replace the copier problem. It might be a problem with the Image Input Terminal, or you might try cleaning the glass or seeing if there is anything blocking the lens but at the end of the day, consultation with a Xerox tech is likely.
3/5/2016 8:22:40 AM • Xerox DocuColor... • Answered on Mar 05, 2016
Computers & Internet Logo
68 questions posted
Top Xerox Computers & Internet Experts
Jim LeVerso - IT...
Jim LeVerso - IT...
Rizwana Ameer
Rizwana Ameer
Level 1 Expert
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Computers & Internet
Most Popular Question
xerox 240 fiery displays ff
  • Computers & Internet
