20 Most Recent
Xerox Workcentre 7435 Color Multifunction Copier 35ppm Duplex 40gb Hard Drive Questions & Answers
How to resolve error code 010-334 in xerox workcentre 7435
Check around the fused assembly. Is it a new one, or is it one you put to one side as as a spare? If you have a service contract with Xerox you should be able to order a new one. I don't remember all they error codes but the 10 codes usually refer to the fuser unit.
Good luck.
Error 041-348
Did you restarted your xerox machine? Restart once and trying xerox again
How did solve the error code 041-348
Hi
This is showing as a memory failure, either check your memory is correctly fitted and not loose, or if it is not then you might have to replace the memory. hope this helps
HOW TO RESET FORGOTTEN PASSWORN ON A XEROX 7435
If the default username and password (admin/1111) are not working on your Xerox 7435 printer, you can try resetting the password to its default settings using the following steps:
Turn on the printer and wait for it to boot up completely.
Press the button with a wrench icon on the printer's control panel to enter the settings menu.
Use the arrow keys to navigate to the "Security" option and press the OK button.
Select the "User Authentication" option and press OK.
Enter the current password, if you remember it. If you don't remember it, leave it blank.
Select the "Reset User Accounts" option and press OK.
Select the "Restore Defaults" option and press OK.
Confirm that you want to restore the default settings by selecting "Yes" and pressing OK.
After you have completed these steps, the printer's password will be reset to the default settings (admin/1111). You should now be able to log in to the printer's settings menu using these credentials.
