When printing text the ink goes over and over text making it blurred when printed. Doesn't happen if l print a photocopy. Just changed to a w10 computer. Was printing fine before. I have installed w10 drivers. What else can l try. Epson support have been very good but don't have a fix for this. I know printer is old but it can only be a software problem. Thanks
SOURCE: epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
SOURCE: test print great, document printing blurred
try to heat up the printhead of the cartridge on hot water about 90degre celsius and clean the head whit a clean soft paper (toilet paper is great and cheap) and make a clean nozle on the printer software.
SOURCE: Epson Printer Setup & Support Number Call 1-8O5-225-669O We are 24 Hour Available Call Now.
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard. Here's what I did. Go to System Preferences. Select Print & Fax. Select the "+" box on the lower left part of the screen. Select Epson Printer -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD. If it does, great. You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work. Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner. I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly. Good luck.
SOURCE: Mac OS 10.5 Leopard
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After
you click ok on the message, you will get another window where you will
find a "manual print" button. Click on this manual print button and
this will take you to the next window where you have to select "A4 as
the paper size" and "CD/DVD as the paper type and paper path" . After
this, click print... it should start to print! This is just a
workaround until epson gets a patch for leopard for print
cd........hopefully
SOURCE: Epson TM-U220D Receipt Printing Problem
mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
