20 Most Recent Epson CX8400 All-In-One InkJet Printer Questions & Answers
2answers
Printer stuck in copy mode--can I reset the printer? Have tried everything.
Hi
Try to turn it off and unplug it for a few minutes, turn it back on and leave it to copy mode. try printing from the computer then/ keep us posted.
Thanks
12/2/2021 1:41:47 PM • Epson CX8400... • Answered on Dec 02, 2021
2answers
Epson CX8400 Blank Pages
i was having the same problem and just got off of the phone with tech support who fixed the problem for me,
go into system preferences
print and fax
there you should see the printer cx8400.
remove the printer by clicking on the - sign.
then re add the printer, by clicking the +
the computer will search for the drivers and install them.
that should have you printing like a champ.
hope this helps.
WW
11/6/2021 7:50:29 PM • Epson CX8400... • Answered on Nov 06, 2021
2answers
Epson CX8400 is printing blank
Hi
You need to replace the printhead
Pls vote us to keep us alive
8/14/2019 6:59:22 AM • Epson CX8400... • Answered on Aug 14, 2019
Epson Stylus NX420 keeps saying
1) Based on the print job, you have to load the paper in the input tray. 2) If you are printing an image and set the paper type as photo paper but if you load the normal paper, the printer will not print properly. 3) It is important to modify the print settings as per the print job. You can look into the user manual and purchase the appropriate papers to print. For more support visit our website @ https://goo.gl/4bc47n.
11/8/2018 6:45:38 AM • Epson CX8400... • Answered on Nov 08, 2018
I have an Epson CX8400 series printer, scanner.
1) Perform the printer hard set once and restore the printer settings to default. Check if the SCSI interface is set correctly on your Windows computer. 2) If there are any interruption connection is made on your computer make sure those settings doesn't interfere with your scanner setting. 3) Check if the name of your scanner appears under the devices connected to your computer. Uninstall the previously installed scanner software and re-install the same after deleting the cache files of the old one. 4) Once the re-installation is done, the scanner will work fine. If it still does not work fine, take the scanner to the nearest retailer and service based on the print job, you have to load the paper in the input tray. 5) If you are printing an image and set the paper type as photo paper but if you load the normal paper, the printer will not print properly. 6) It is important to modify the print settings as per the print job. You can look into the user manual and purchase the appropriate papers to print. For more support visit our website @ https://goo.gl/4bc47n.
11/8/2018 6:43:28 AM • Epson CX8400... • Answered on Nov 08, 2018
How to physically clean printer heads of Epson CX8400 ?
1) Cleaning the print heads physically is not a tough task, but it is important to handle the printer parts gently. Use a lint-free cloth and distilled water to clean the print head. 2) With the printer turned on, open the top cover and allow the print head to settle in its position. You can move the printer carriage by hand. 3) The print head would be covered with ink. Take the cloth and use some mild cleaning liquid or distilled water. 4) You can purchase some syringe if you need to clean the internal parts of the printer. Wipe away the ink and don't use the same cloth if the ink stain fills the cloth. Repeat the step until the cloth doesn't get ink stain. For more support visit our website @ https://goo.gl/4bc47n.
11/8/2018 6:40:52 AM • Epson CX8400... • Answered on Nov 08, 2018
2answers
After cleaning print heads,which were causing poor
Head cleaning procedure consumes a lot of ink. Ink level counter run too. So, after some head cleaning ink level counter reach zero level (ink out/empty level). Ink tank can not use again even there are ink at tank actually, because chip reach zero level. Reset chip using hardware resetter and you can refill ink tank.
10/27/2018 8:18:14 AM • Epson CX8400... • Answered on Oct 27, 2018
3answers
Epson cx8400 printer error
In order to fix error code cx8400 on Epson Printer, make sure that you have removed the cartridge once, and then place it back again. If you don't know the process, you can take help of the manuals given to you along with the device. And, if by chance, your issue is not resolved even after resetting the cartridge, it is important for you to take instant help from the experts. Just call them now on Epson printer support phone number to connect with the professionals, and they will quickly resolve the problems. epson printer-wzyablwzp1lyhe5npqtfmovu-4-0.jpg
2/14/2018 11:25:03 PM • Epson CX8400... • Answered on Feb 14, 2018
11answers
Can't print to Epson CX8400
I had the exact same problem with the endless blank pages "printing" out.  I have a MacBook Air with OSX 10.5.6.
Before I got a chance to try and delete and reinstall all the drivers all over again, my phone call was answered by a very helpful lady from Epson's support line US: 562-276-4382.
Here's how easy it was to fix: Go into Apple System Preferences, click Printer & Fax. HOLD CONTROL while clicking on the printer on the left side of the screen.  When you HOLD CONTROL, it allows you to choose the option to "Reset Printers".
Click "Reset Printers", and you will see them all disappear.  Simply plug in your CX8400 and click the plus button to add new printer.  It will search for the driver for you if you have an internet connection.  It worked for me on the first try and took only about 2 minutes total!!!!
I'd wasted so much time installing drivers and screwing with the printer before this.  Save your time for things that make you happy!  Share help when you can!
2/14/2014 11:24:04 PM • Epson CX8400... • Answered on Feb 14, 2014
0answers
0answers
Print Error 9781
send me sotware panasonic kx-mb772 to download
12/20/2013 9:46:36 AM • Epson CX8400... • Answered on Dec 20, 2013
2answers
HP officejet Pro L7580 print head is not working properly.
i order the 8 jan 2010 2 print heads No : 88 (ref hp c9381a for black/yellow and ref hp c9382a for magenta/cyan) and i receive it after 4 days.
11/29/2013 8:56:24 AM • Epson CX8400... • Answered on Nov 29, 2013
Ink cartridge replacement
I had the same problem, and after scouring around online for a few days, I learned that this is one of the biggest gripes about this printer. Basically, you're out of luck unless you replace EVERYTHING, even though you only want to print black (nuts, isn't it?). So I went out and bought all new color cartridges, and it STILL won't print. I think it's just a bad printer all around. :(
11/26/2013 1:08:05 PM • Epson CX8400... • Answered on Nov 26, 2013
Epson CX8400 All-In-One InkJet Printer Logo
227 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
epson tx720wd printer error thurn power
  • Office Equipment & Supplies
