20 Most Recent Epson Stylus Color 740 InkJet Printer Questions & Answers
0answers
How to clean inkjet nozzles on hp psc 1300
I don' t know if this problem has been solved since... In another similar occasion with my Epson Stylus D78 all I did again was to let the job done by my Mac (operating under OSX Version 10.9.4 dubbed "Mavericks" - I presume under Windows it works similarly- ). It searches , downloads , and invites one to install the driver of the printer. Then use "printer utility" and clean nozzles, and others functions ( print test pages , etc..) . Of course, one can do similar tasks right on the printer, such as pressing over more than a few minutes various buttons on the printers ( couleur , page button etc..). Do it randomly !yes, one learns and it works! if manuel is lost or google for manual. Hope it helps.
9/20/2014 8:56:05 AM • Epson Stylus... • Answered on Sep 20, 2014
All lights flashing
Turn off printer and disconnect power lead, then go into your computers printer setting click see whats printing and delete any jobs in print que. Restart your computer plug your printer power lead back in.
3/16/2014 2:10:53 PM • Epson Stylus... • Answered on Mar 16, 2014
3answers
Epson 740 displays 3 red flashing lights on power
See your other ticket...
For those who are visiting and seeing this... it's a service required indicator.
9/12/2013 8:36:35 AM • Epson Stylus... • Answered on Sep 12, 2013
2answers
Epson 740 printer seems totally dead, all lights are blinking.
Already solved.
9/12/2013 8:22:52 AM • Epson Stylus... • Answered on Sep 12, 2013
2answers
I TRY TO PRINT ONE PAGE AND THE PRINTER PRINTS
This happens when you have the wrong driver software loaded into your computer. Try printing a test page directly from the printer. Hold the 'page feed' button as you power up the printer. This will tell you if the printer is working. If this is ok, try a different print driver in your computer.
8/20/2012 8:30:15 PM • Epson Stylus... • Answered on Aug 20, 2012
2answers
Head cleaning not working
Doesnt sound like you Used Genuine Cartirdges?
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
10/4/2011 6:26:00 AM • Epson Stylus... • Answered on Oct 04, 2011
Epson stylus cant find a driver for it to work on
There are no XP drivers for this printer.
It is possible that Windows N.T. 4.0 or windows 2000 drivers may work.
You can get them here.
9/23/2011 9:37:48 PM • Epson Stylus... • Answered on Sep 23, 2011
Can not use epson color
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
12/6/2010 2:03:13 PM • Epson Stylus... • Answered on Dec 06, 2010
I do not need to
you must have both cartridges fitted for the printer to work. The colour cartridge can be empty if you don't want to print any colour, but it must still be in there. When the ink monitor prompts you to replace the colour cart, just lift it out and push back down. This will reset the ink counter.
This is ok to do in emergency, but not a good practice as you'll end up with colour printhead full of air. If you're doing this to save ink, just buy some generic colour cartridges, they're quite cheap.
hope this helps
LC
www.inkbank.com.au
11/12/2010 1:40:14 AM • Epson Stylus... • Answered on Nov 12, 2010
2answers
Install new cartridge will not print smudges only
Hi, you have to carryout a fault finding sequence. Access printers, right click on printer icon (Default) menu/click properties/setup. if not lists there/look on the menu for checking/repairs/.
10/8/2010 4:47:51 AM • Epson Stylus... • Answered on Oct 08, 2010
Blurred black printing
Run maintenance and clean printer head
9/20/2010 5:36:29 PM • Epson Stylus... • Answered on Sep 20, 2010
Epson Stylus Color 740 Printer is out of ink but
Just pull the carriage gently in position with your hands, with the printer unplugged.
7/2/2010 6:57:53 PM • Epson Stylus... • Answered on Jul 02, 2010
My wufe attacked a paper jam and now it will not
adjust or remove paper tray
6/25/2010 7:18:05 PM • Epson Stylus... • Answered on Jun 25, 2010
MY Epson 740I will only print in black and white.
In any program, when you choose Print, it will print setting dialog, then you click Property button, under Main tab, in the ink selection, select color. It should work.
CompQ
5/12/2010 3:53:41 AM • Epson Stylus... • Answered on May 12, 2010
My Epson 740, don't print, I have change the
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
4/29/2010 10:07:41 AM • Epson Stylus... • Answered on Apr 29, 2010
Lights will not go out
Thanks for writing to Fixya.com.
Make sure there is no paper jam and the printer cartridge are working fine. When all the lights flash, that indicates a maintenance request. If your printer is under warranty contact the EPSON Connection Technical Support or an authorized Epson servicer for assistance.
http://www.epson.com/cgi-bin/Store/timeout_error.jsp?cookies=no&oid=14413&infoType=FAQs&category=Products&Failed_Reason=No+BVCookie+present+to+retrieve+the+session.&prodoid=8296&com.broadvision.session.new=Yes&Failed_Page=%2Fsupport%2FsupDetail.jsp
Thanks for contacting Fixya and please accept the solution if it has helped you.
4/19/2010 6:15:03 PM • Epson Stylus... • Answered on Apr 19, 2010
Epson Stylus Color 740 InkJet Printer Logo
84 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
all lights flashing
  • Office Equipment & Supplies
