SOURCE: Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
SOURCE: Can't fine servers during LDAP search
hi
try to change the setting of lancard speed to half duplex of photo copy machine
SOURCE: E000
A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
Here's the definitive reset procedure
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
please rate my answer after trying if satisfied
SOURCE: Cannon image runner 2200 error code E000002-0000,
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom
E002/E000/E003/E261/E733: due to AC line noise.
Description
E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise.
Cause
When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times.
Field Remedy
Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise.
REMEDY
Caution
Press (* then 2 and 8 together then *)you are in service mode monitor:To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
SOURCE: cannon image runner 2200 Error code E000019-0000
Empty the waste toner container. From left side of copier you have small cover with one screw.Remove the cover and empty the container and clean it very well, you may use alcohol for the neck of the bottle to ged rid of of antistatics.
