20 Most Recent
Cannon i70 Printer Questions & Answers
Canon i70 printer clicks when paper is loading
Joseph,
I have the same exact issue with my Canon I-70. I like to attempt to fix things on my own so I opened it up and discovered that one of the main gear wheels that operate the paper feed rod is cracked. I am not sure if it was always like that (I doubt it), but the whole gear wheel is cracked so the gear teeth have separated a bit. When the printer attempts to feed the paper the gear turns and when the cracked side where the teeth are separated hits the other gear connected to it the misaligned teeth do not allow it to proceed. Honestly it looks like a very simple change of the gear wheel will solve the issue. My problem is that I do not know where to buy this piece.
Can someone help me to find the specific gear wheel?
Dennis
Paper wont feed
Could be a piece of paper stuck somewhere, open all access areas and check carefully, sounds like an obstruction somewhere
Canon not print 2900 lbp
Go to usa.canon.com and download the appropriate driver. Most generic drivers that come with windows don't work well with the canon products
Loud noise after paper jam
what kind of noise? if paper has been removed check to make sure there no leftover pieces wedged in the rollers.
I no longer have my installation CD for my cannon
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You can download the required installation drivers from manufacturer's site by
clicking this www.cannon.com
Select and download the drivers according to the operating system of you
computer (Win XP/Vista,others...)
I have a Canon ImageRUNNER 2200. I would like to
This error is with the DC controller board needing replacment or repair. This would take a service tech to come to your home/office to fix. We only can tell you what the causes are, it will need you to follow up on the fix. The charge for service on a DC controller is over $400 alone. I recommend if you have a service contract to give them a call.You can call these folks and see if they can do service in your area:Chess, inc410 Raritan Way Denver, CO 80204(303) 573-5133They are really good at what they do, I do highly recommend them for repairs on your unit.Thanks and hope you have good luck in repairing this issue. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
