I got a free sharp notevision PG-m20x. I plug it in and the red light on the power button comes on. I push the power button which then turns green the fan turns on and the Lamp light turns green and slowly flashes. After about 5-10 seconds the fan turns off and the power turns off and red light comes on. Any suggestions would be great.
IMPORTANT question--does the lamp ignite at all when the power button turns green?? I'm gonna give you some scenarios... 1) if lamp does ignite, the problem could be a bad cooling fan--either not turning or not putting out a computer signal *indicating* it's turning to the main board 2) If lamp *doesn't* ignite, problem could be a bad lamp--remove and inspect the lamp for dark bulb, bulges or blisters on the glass showing the lamp has reached the end of its life--and/or a bad ballast(the circuit that controls the lamp ignition and burning)
