20 Most Recent
Sharp Notevision PG-C45X Multimedia Projector Questions & Answers
I have a sharp notevision DLP xr10x projector. Two
Hi Stephen,Do you hear any fans starting when you turn on the projector? Try unplugging and then plugging in the projector. Make sure that the lamp door is secured as the projector will not start if it is loose. You should also reset the timer for your projector. The manual can be found on the site of www.allprojectorlamps.com.
Rest light imer on sharp
Turn on projector, press and hold the input, enter and undo buttons on the projector then while still holding those three press the on button. Make sure you do this before the timer goes to 0% or it wont turn on again.
I just got a used
your bulb is going bad, replace it and the problem will be resolved.
My projector overheats quickly
Two possibilities:
1) Air filter is clogged and preventing proper air flow
2) Lamp is getting old and is less efficient, creating excess heat.
For option 1, check the air filter located on the bottom of the projector. Page 81 of the manual details this process:
http://www.wrcs.k12.mi.us/Technology/How%20Tos/Ceiling%20Projectors%20PGC45X.pdf
Once you have removed filter,either replace or clean out with vacuum or simply blowing out the dust
Option 2: if you have used the projector for over 1500 hours, there is a good chance the lamp is close to the end of its life cycle. Check to see if the lamp replacement light is on; it is just below the power button on the unit.
If you are feeling adventurous, you can take out the lamp by following the instructions on page 86 of the manual: http://www.wrcs.k12.mi.us/Technology/How%20Tos/Ceiling%20Projectors%20PGC45X.pdf
Once removed from the unit, see if the lamp has any bubbles or crystallization. The crystallization makes the mirror in the lamp look muddled, rather than crisply reflecting light.
Hope this helps.
Reset password on sharp PG-C45X projector
I am not sure what the sequence is but sometimes you can hold a couple of buttons to reset this. The problem is that sharp does not like to say what the procedure is and that you will need to find a local dealer to help you with this. You may be able to do this over the phone or will need to drop it off.
