SOURCE: sir i want to know
Which one? board number? so I can some research. Posting the Pictures will help. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Replacement board: http://www.lcdrepair.us
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
SOURCE: Sansui AU-D77X left channel output transistors
the first thing the tech must do is to insure that there is no more than 2V on the base of the
pre-drivers of the driver transistors.
If it do then connect the pre drivers and monitor for:
a ) DC offset
a good amp never produce an over of 0.7V on its output
b ) measure the idling current , more than 80 mA is hazardous to your output
transistors.
Test and continue listening for a day.
( without the output transistors )
you can even series additional resistors on the emitters to be safe
( like 100 ohms on each )
Better if you can work and test the amp in about 1/2 of the AC supply.
( if your using 220V trim the supply to 110V )
These pre-drivers are the determining point of the life of your amp.
These may run hot , but will never burnt
( assuming there are no more faulty components starting from the input )
If it does then you may have to check the VAS circuits
and the long-tailed or differential input circuits.
If these works for a day , then connect your output transistors.
These are your pre-driver transistors ( left side of yellow line )
output transistors (right side of yellow line )
they should be replaced in pairs
