Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you didn't fry speakers as well. Please check speakers impedance.
A thumbs up would be greatly appreciated if this answer is helpful to you
Disconnect the speaker wires then the power and ground completly. Then power up the amp and if the protection light turn on the you have an interanl problem if not then you ohm is problably to low and causing the amp to go into protections.
The fan looks very similar to a 3" muffin fan. The fans from most computer cases would probably fit. You may have to modify how it mounts, and perhaps the connector, but the voltage is the same.
Here's an online retailer. I'd look for the highest CFM at the lowest fan speed to keep the noise down.
You can try opening it up check the circuit board and see what capacitor burned up or other resistors, transistors got burned and go to Radio Shack and solder the new one to replace the burned one. Or if you still have the reciept return it to the manufactorer and hope it has a 1 year Extended service protection on it so they can replace it.
well you could be having several issues but it will most likely be one of two of these issues. there could be a cross or a loop in your setup, or you could have and over heating problem. do you have a capacitor hooked in to your system?
When ever the amp stays in RED protection mode with out any speakers hooked up to it, YOUR amp has internal damage some where. Can't tell you how much to fix, Could be cheap or not worth it. Talk to your local electronic repair, would be a good start.
I had a similar problem with a pyle amp. try to disconnect the speakers and turn it on if the protect light doesn't come on then you might have blown something in your amp and it needs to be repaired. For my situation it was a blown resistors and only 1 channel worked. If you don't have soldering experience then I wouldn't bother trying to fix yourself, an unsteady hand can ruin your repair.
12vDC CFM is negotiable - as the higher RPMs the more air it moves. (also louder). Audiobahn is out of business - and unless someone is willing to tear theirs apart for your info - get whatever they have in stock :)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
did you check on the 'remote' terminal? It should have a +12 vdc to let the amp work. You can check this with a voltmeter. Or might be in 'protection mode' (speaker cut-off relay).
hope this helps
