Unfortunately, no. Although the Foxtel iQ3 and iQ4K STUs do have Bluetooth functionality built in, it is only used for pairing a compatible Foxtel remote control - Bluetooth audio is not supported. You will need to pair your headphones with your television set which will transmit audio from the Foxtel STU via HDMI.
SOURCE: Jawbone bluetooth won't pair with phone.
sometimes the phone will not pick up on certain bluetooth headsets so i recommend a Motorola.
SOURCE: Problem with maintaining paring with Palm Pre and Moto H560
I fixed the problem, at least partially by disabling and reenabling bluetooth on the Palm Pre. The headset now automatically picks up the audio from phone calls. If you go out of range of the phone however the problem starts all over again. Recycling the power on the headset does not fix the problem.
SOURCE: PAIRING PLANTRONICS BLUETOOTH WITH IPHONE 3G
On your phone. goto the Bluetooth menu and select "Add Device or Add Headset"
Refer here to put the headset into pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
SOURCE: bluetooth won't pair
Did you try this?
