20 Most Recent
Samsung S3650 Corby blackwhite + WEP 490 Corby Bluetooth Earpiece Headset Questions & Answers
How do i pair with an iphone 3g
On
your phone, make sure bluetooth is turned on (settings, general).
While
your phone is in discovery mode, turn your bluetooth device on and put
it in discovery mode (usually you have to hold the power button for 7-10
seconds).
Your phone will find the device, and you will be
prompted to enter the devises PIN number (often 0-0-0-0). Your phone
should pair with the device then.
Samsung corby simlock
ya sure using the codes you can solve this sim lock problem for your samsung mobile because its safe for your mobile......Get the unlock code for your samsung corby model mobile from this site
Onlinegsmunlock.com , here it gives the easy methods to get the mobile unlocked.........
How to format samsung phones?
You can't format it, all you can do is to reset it, this will wipe all customer settings and brig it to default ones.
MY LG TONE HBS-730 stuck on incorrect pin
i have samsung mobile
Here are some steps you can try:
Reset the Headset:
Turn off the headset.
Press and hold the REW (rewind) button and the PLAY/PAUSE/STOP button simultaneously for about 5 seconds until the LED indicator flashes purple.
The headset will reset, and you can try pairing it again.
Pairing with Samsung Mobile:
Make sure your Samsung mobile's Bluetooth is turned on.
Slide the power switch on the LG HBS-730 to the "ON" position.
The LED indicator on the headset will be solid blue, indicating it's in pairing mode.
On your Samsung mobile, go to the Bluetooth settings and search for new devices.
Select "LG HBS-730" from the list of devices.
If prompted for a passcode, enter "0000" (four zeros).
Once paired, you'll hear "Your headset paired."
Check Battery Level:
Press and hold the VOLUME DOWN button for 1 second to check the battery status. The audible alert will indicate the battery level (high, medium, or low).
Charge the Headset:
Connect the charger to the headset. While charging, the LED indicator will show a solid red light.
When charging is complete, the LED indicator will turn off.
Remember that the headset will automatically turn off if not paired within 3 minutes.
If these steps don't resolve the issue, refer to the HBS-730 User Manual for more detailed instructions.
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
