Windows 10 is Plug and Play so connecting the printer by USB cable, Win 10 should auto-discover it once it is powered up.
If the printer not found message happens after connecting the cable and then auto-discover faults, might try a different USB port on the PC or a different USB cable.
If the error occurs when scanning for new devices, pretty much the same thing goes.
Or the printer has an issue and will not communicate over USB for some reason. Perhaps a factory reset of the printer settings, to clear some erroneous setting, would help.
Last suggestion: make sure your Windows 10 Update is run to take all the latest patches (may take several Update/Reboot cycles to get them all), and that the OS is properly licensed and activated with a valid license key. Some features are disabled when the OS is not activated. Anti-virus software might be blocking the software install needed. If the printer came with a disc, connect the printer, power it on, insert the disc and see if it will install a driver.
The web site shows this printer is discontinued so maybe it is old enough that they didn't produce a Win 10 driver. Windows Update should pick one up if it is available as most HW manufacturers publish their drivers through the Windows Update process.
https://www.lexmark.com/en_us/printer/2236/Lexmark-E232
SOURCE: hello
You can download them here http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:448:0:0
SOURCE: installing Lexmark 1200 series
Cannot install original Lexmark All in One disk on new computer. Windows Vista Home Premium.
SOURCE: Can't print from MacBook, through Time Capsule, to Lexmark x5470
turn on the printer sharing via the system preference panel on the computer that is on the system via usb.
Then on your wifi computer look for shared printers and you'll see your printer in the list under the host computer name... use that setting and it should fire up for you!
let me know how it goes...
SOURCE: Need to install my Lexmark E232 but don't have the software
you will have to go its website www.lexmark.com and download the necessary softwares for installing your printer. further chat with me for any help [email protected]
SOURCE: Page Count Report for a Lexmark E232
Print test page direct from a printer - press Continue ("Diamond button").
