SOURCE: Riso EZ 200E model gives error message A-34 -218
It means to reset the master material in the master making unit. Should be ok after that.
SOURCE: ez 200 riso error code
The Cutter HP switch does not go ONwithin 2 seconds after the cutter homepositioning operation started. (Shuttlecutter only)
to fix this.open the master making unit under the metal pc. attached to the green bar you will see a small white peice somewhere along it.slowly and gentely move it all the way to the left.reset the master making unit and put it back in the machineturn off the power switch and start the machine holding the left and right print position arrows.when it starts press the yellow clear button until you see all zeros on the screen.enter the following code.110 press start. when it beeps press the c on the key pad enter 111 and when it beeps press the c on the key padturn machine off and back on... code should be gone!
SOURCE: HOW TO FIX ERROR P98-6 ON RISO EZ 200E
www.fixya.com/support/t17447669-risograph_ez_200e_shows_error_code_p_98
