20 Most Recent
Riso RZ220 Duplicator Questions & Answers
I cant return the drum for my machine risograph
This meens your Riso's timing is out.Put your drum in home possition by rotating it untill it locked.Slide the drum back into the machine.If this doesnt help you will have to realign the machine to the home possition.
Switch the machine off.At the back of the drum there is a gear that have to align with the Main drive gear of the machine.Turn the main drive gear untill the guides of the gear matches the drum' gear.But remeber that gear doent move easely.
Try to slide the drum back again.
Be carefull not to cut yourself with the inner plates of the machine
RZ200 error code A06 403
The error code "A06 403" on the RZ200 duplicator indicates a problem related to the master-making process. This error can occur due to various issues within the machine. Here are some steps you can try to proceed with resolving the error:
- Power Cycle the Machine: Turn off the RZ200 duplicator and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. This simple reset might clear the error if it was caused by a temporary glitch.
- Check for Obstructions: Inspect the machine's internal components, such as the master-making unit, ink cartridges, and paper feed, for any visible obstructions or jams. Clear any blockages carefully.
- Clean Internal Components: Dust and debris can sometimes cause errors in the duplicator. Clean the internal components, particularly the master-making unit, with a soft, lint-free cloth or a compressed air duster.
- Inspect Master-Making Unit: The "A06" error code often relates to the master-making process. Check the master-making unit for any signs of damage or misalignment. Ensure that the master roll is loaded correctly and that all components are properly seated.
- Check for Ink Issues: Inspect the ink cartridges to ensure they are installed correctly and have enough ink. Low ink levels or improperly installed cartridges can lead to errors.
- Update Firmware (if applicable): If there is a firmware update available for the RZ200 duplicator, install it. Firmware updates can sometimes resolve known issues and improve performance.
- Refer to the User Manual: Consult the user manual or the manufacturer's documentation for the RZ200 duplicator for specific troubleshooting steps related to the "A06 403" error code
Error code A06-403 THE
Sometimes when people lift the machine, they don't use the handles, there is a plate underneath the paper tray that bend, bend it straight and all will be fine
Code D-17-236
A D17 is incorrect master roll installed. This could be caused by a) it IS the incorrect master roll, or b) the RF tag that is inside the master roll has gone bad. Try a new one in the original packaging to help with diagnoses. Make sure they are RISO Z type master rolls specific for an RZ220.
A17-209 error message
A-17-209 is a cutter error meaning the cutter is not at home position when master material is in place. The cutter can be manually slide towards front of machine or another way is to rerolled master paper back on to its roll and close the clamp. This will cause the cutter, if operational, to re-home itself correctly. There are test codes to operate cutter to check it (480).
Code:p-01-537
this is a very tricky problem on the main motor ther is a steel cap covering a strobe disk and a sensor the sensor is dirty or faulty to get to it you have to take out the main motor
