20 Most Recent Riso RZ390 Duplicator Questions & Answers
2answers
CODE E4 RISO KS800
ink overflow --inside the printing drum there's a small circuit with two pin ( like needles)....there is one shorter than the other, they are very thin... you have to clean them with a small swab and alcohol, be very carefull, don't bend them....hope this be usefull to you :)
1/13/2020 8:48:27 AM • Riso RZ390... • Answered on Jan 13, 2020
8answers
Error code E4 for riso ks800
riso ks 800 error code c-7
3/15/2019 1:21:55 PM • Riso RZ390... • Answered on Mar 15, 2019
Error Code P-04-513
P04-513 is an ink overflow error.the easiest way to fix it is to run the drum dry.here is how:1. turn the machine off by the power swith.2. hold the left and right print position buttons and turn on the machine.3. when the machine starts it will show you some numbers.. perss either the clear or yellow reset button to show 00004. now enter 81 and press start and the machine will make a master.5. once the machine is done press the clear or yellow clear button to return to 00006. next make suer you have plenty of paper and enter 888 and press start.. the machine will start making copies of the test pattern. (if it jams a lot you may want to use speed 1 or go to step 4 and use code 80 instead)once the copies start coming out light you can press the stop button and when the machine stops turn it off and back on normally.
3/15/2019 6:21:25 AM • Riso RZ390... • Answered on Mar 15, 2019
Riso RZ 220 UI The master drum will not come out
This is for master drawer not responding to green light to be released question. Try turning ON machine (turn off first) while holding down the reset button. Also a mechanical way is a small hole to insert a pencil, eraser end first, just below green latch area. Just insert hold in while squeezing release latch. to drawer.
2/21/2019 2:16:23 PM • Riso RZ390... • Answered on Feb 21, 2019
2answers
NEED INTERFACE DRIVER FOR RISO RZ 370 ..
US.RISO.COM
goto the support page... on the top colorfull bar and from there goto technical support then create an account and find your driver...
1/5/2019 2:36:03 AM • Riso RZ390... • Answered on Jan 05, 2019
0answers
3answers
RZ390 Risograph has light for ''CHECK SETTINGS''
Just had the same thing happen. The ink cartridge was not completely in the lock position. Once I remove the ink, reinserted it and locked it, everything was back to normal.
9/15/2015 8:35:36 PM • Riso RZ390... • Answered on Sep 15, 2015
How do you enter user codes on a riso RZ 390
by pressing print position keys Plus 15 & minus 15 at a time with one hand and by using other hand machine power on, and release both keys u will in test mode
4/25/2015 6:57:06 PM • Riso RZ390... • Answered on Apr 25, 2015
Why do not feed more than one or two pages
Check if there is dust or if the output is holding paper sheets to pass. It may be that some of the gear output paper is loosely screw on the shaft causing the problem. Also check the registration sensor inside the machine and clean it. I hope I helped you.
10/6/2014 2:42:38 PM • Riso RZ390... • Answered on Oct 06, 2014
How to adjust a clutch on a Riso GR 3790?
Chances are good the clutch does need to be replaced. These are magnetic and while they can be cleaned, eventually they will fail and parts are no longer generally available. As well if you pull the clutch to clean it you have to be VERY careful to mark everything and lock the gears into place. Retiming these old guys if they lose timing is something I'm successful at about 2 out 3 times. Most of them are pretty worn out and nothing wants to quite line back up right once you lose it.
8/12/2014 12:02:47 AM • Riso RZ390... • Answered on Aug 12, 2014
0answers
0answers
0answers
3answers
I have a riso duplicator
Its possible that the ink drum has not correctly installed. Check your RZ390 Owners Manual for this subject and the troubleshooting and error codes for solve.
Sometimes, the label on the ink cartridge oulet surface has come off or surface is with dirt, this problem appear.
Hope help with this.
5/15/2014 8:41:24 AM • Riso RZ390... • Answered on May 15, 2014
0answers
Code p-19-207
Be the first to answer 4/29/2014 12:14:01 AM • Riso RZ390... • Posted on Apr 29, 2014Be the first to answer
141 questions posted
Top Riso Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Riso Office Equipment & Supplies
Most Popular Question
error code e4 riso ks800
  • Office Equipment & Supplies
