1, To solve the faded print problem, follow the steps given below.
2, Use the genuine HP toner. The HP does not guarantee the quality or reliability of non-HP toners.
3, Make sure that the papers used for printing are appropriate for the print job.
4, Make sure that the print settings are aligned correctly to your print job.
5, You can check the settings from the Properties option on your computer.
6, Check the status of the ink level and replace low or empty cartridges.
7, Check for any damages on the printhead. If it is damaged, replace the printhead.
For more printer queries just give a call @ 1-866-293-9220
Sometimes if the page from the printer comes out faded it seems like the ink is low if not you will have to change the printer settings so it will print full dark ink on page. there are settings to print a draft or full dark print out. see if it is set on draft
SOURCE: faded stripe down the printed page
I found a solution that worked to eliminate the faded black stripe down the page thanks to a post by slamfix in another forum. The problem is related to ink build up on the blade edge of the black developer assembly in the imaging unit (the imaging unit contains 4 separate developers - yellow, blue, magenta, and black). The solution involves taking out the imaging unit, removing and cleaning the blade edge of the black ink developer until smooth. It took me about 15 minutes to complete and was fairly straightforward.
Detailed instructions with pictures can be found at http://losingambition.com/clp300imagefix/
SOURCE: hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
SOURCE: printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
