SOURCE: Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
SOURCE: z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
SOURCE: How do you replace a drive belt on a husqvarna cz4817
i just replaced my belt on a cz 4817. On one side there should be a bar with a spring on it. If you sitting in it it will be on you left side mounted on the deck itself. Push the bar in for about an inch and then up over the lip thats the belt tension spring. you should now be able to remove your old and put the new on. If you need the diagram to show you how to lace the new belt let me know and i will email it to you. good luck
SOURCE: Drive Belt routing for Scotts Riding mower
I have to replace the belt part number m124895 on a Scotts riding mower.I need the belt configuration,since i bought it used.
Please help
SOURCE: Husqvarna zero turn mower backfires and stalls when mower blades on
sound like a carb problem clean the jets out
