20 Most Recent Husqvarna Rz4623 46" Ztr Lawn Mower Zero Turn 23hp Kohler Engine Questions & Answers
Husqvarna RZ46i 23-HP V-Twin Dual Hydrostatic 46-in Zero-Turn Lawn Mower moves fine in reverse but not forward.
Question edited for clarity, full 'make model (what it is)'. Question moved from Cars and Trucks. Some ideas here https://www.google.com/search?q=Husqvarna+rz46i+drive+slipping ..
6/28/2022 1:42:46 AM • Husqvarna Rz4623... • Answered on Jun 28, 2022
2answers
My mower is running fine. However, when the
Make sure the blades spin freely. Replace the deck belt.
9/27/2021 4:09:37 PM • Husqvarna Rz4623... • Answered on Sep 27, 2021
My husqvarna RZ4623 wont move. the engine wouls die if i engaged arms, blades, or removed parking brake. i bypassed seat relay now it will engage blades i can lower parking brake but handles do nothing. does the seat relay have to be in place for mowers handles to engage? or do i have another issue?
If not in bypass, likely you lost the pump drive belt, item 5 in following diagram. https://www.partstree.com/parts/husqvarna/mowers-zero-turn-lawn-mower/rz-4623-966764501-husqvarna-zero-turn-mower-2011-03/hydraulic-pump-motor/
3/10/2019 4:46:35 PM • Husqvarna Rz4623... • Answered on Mar 10, 2019
Mover sometimes does not move and other time moves real slowly
ck belts that run hydraulic pumps for tire drive , it might have slipped a bit with chain caught , now belts skid instead of transferring power to pumps , also these pumps might have a manual pressure relief reset , I was thinking they only used them on bigger units , but you might have one as well ,hey its possible , this will need to be reset prior to continuing mowing (refer to manual for location )
6/3/2017 5:23:28 PM • Husqvarna Rz4623... • Answered on Jun 03, 2017
While mowing the blades disengage and engage ?
Is this just when you pull the steer lever into reverse ? Most are made that way and I think the newer ones offer a bypass on them to stop that. The old one just get a jumper wire on each steer lever to stop it.
12/22/2016 12:34:45 PM • Husqvarna Rz4623... • Answered on Dec 22, 2016
My blade will not stay engaged to mow. how do I fix the problem?
When you say will not stay engaged you are saying that it comes on then cuts off ? If you turn on the PTO and it engages and the mower is not moving does the PTO stay engaged and for how long (if OK then need to check connections for PTO ) . If it is not engaging at all then we have to look at interlocks / safety switches . Give me some Details If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
4/18/2016 3:23:25 AM • Husqvarna Rz4623... • Answered on Apr 18, 2016
Diagram of drive belt for husqvarna rz4623
Hi Willard, The link below is a web page with the diagram for your lawn mower.......CHEERS.. Diagram of drive belt for husqvarna rz4623 Google Search
4/17/2016 12:31:09 AM • Husqvarna Rz4623... • Answered on Apr 17, 2016
Start idle but shut off when I attempt to move the hand brake
Probably a bad safety switch on one of the steering arms
1/8/2016 11:27:46 PM • Husqvarna Rz4623... • Answered on Jan 08, 2016
Won't crank, flashes oil then says 0.9. Stick says full oil
Low oil senser might be bad and this will not allow it to start.
1/8/2016 10:55:43 PM • Husqvarna Rz4623... • Answered on Jan 08, 2016
Will not start.
First, remove fuel line from carb. Fuel should run out
8/28/2015 11:49:25 PM • Husqvarna Rz4623... • Answered on Aug 28, 2015
Why mower will not move forwardo or backward I've replaced the idle pullt
There is a switch under you seat or attached to your seat somewhere that is probably not activating or is bad. This switch has to be fully depressed to activate the drive. It is a safety feature.
8/14/2015 1:46:59 AM • Husqvarna Rz4623... • Answered on Aug 14, 2015
My RZ4623 will not move.
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
5/20/2015 5:37:41 PM • Husqvarna Rz4623... • Answered on May 20, 2015
Was cutting and stop moving forward and back wards belt in good condition
Could have broken the shear pin in the drive pulley. If one of the pulleys turns when you put it in gear but the other pulley does not turn then the shear pin is broken or missing.
4/5/2015 12:51:31 AM • Husqvarna Rz4623... • Answered on Apr 05, 2015
0answers
Husqvarna Rz4623 46" Ztr Lawn Mower Zero Turn 23hp Kohler Engine Logo
40 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
  • Garden
