20 Most Recent Husqvarna 128 LD Weedeater Questions & Answers
Its running too lean on the carb mixture, you need to richen up the H screw on the carb, if not marked it will the adjusting screw furthest away from the cylinder, this will increase fuel to the engine if turned out ( anti clockwise ) you will be to purchase an adjustment tool, this is because there is no slot in the screw, it has a spline so the tool has an internal spline to fit the adjuster, the are readily available on e bay, once you have the tool, unscrew the adjuster onlt 5 minutes on a clock face.
Husqvarna 128 LD... | Answered on Jul 09, 2019
It’s 1/3 cup oil to 1 gallon gas
Husqvarna 128 LD... | Answered on Jul 28, 2018
I have a Husqvarna 128LD and love it. When using a tiller attachment the part of the shaft that has the knob comes loose. I have tightened the screw with allen wrench but it still comes off. or gets loose. Can I weld the bracket to the shaft?
Husqvarna 128 LD... | Answered on Oct 15, 2017
Not sure if you are asking about the throttle assembly or carb. Both of these are available as kits from Husqvarna and will save you a big headache trying to rebuild.
Husqvarna 128 LD... | Answered on Feb 22, 2017
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Husqvarna 128 LD... | Answered on Jun 30, 2016
You have to take it apart, get the spring back in, then wind the cord around around it. Not an easy task if you've never done it. A small engine repair or lawn mower repair shop will fix it pretty cheap and fast.
Husqvarna 128 LD... | Answered on Apr 22, 2016
Its definitely the carb. "cleaning" the carb usually is not a fix alone on those 2 cycle carbs. You should rebuild and clean it. The small diaphrams in those get tiny holes, and the fuel now days plays havoc on them.
Carb kits are inexpensive, just make sure you re-assemble everything in correct order.
Husqvarna 128 LD... | Answered on Apr 13, 2016
Husqvarna 128 LD Weedeater Repair Questions,... - Fixya
www.fixya.com > Forum > Lawn Trimmers & Edgers > Husqvarna
Recent Husqvarna 128 LD Weedeater questions, problems & answers. Free expert DIY tips, ... Drive head rotates counter-clockwise. Can't get it back into ...
HOW TO CHANGE HEADS ON HUSQVARNA 128LD - Fixya
www.fixya.com/support/t20975899-change_heads_husqvarna_128ld
Oct 25, 2013 - Question about Husqvarna 128 LD Weedeater ... SOURCE: MyHusqvarna 128LD primer bulb .... Drive head rotates counter-clockwise.
Weed eater bogs out at full throttle - Fixya
Husqvarna 128 LD... | Answered on Dec 06, 2015
More investigation and information required, possibly damaged piston rings or crank bearings.
Husqvarna 128 LD... | Answered on Jul 25, 2015
1.5 out each usually... Try it around there I guess
Husqvarna 128 LD... | Answered on May 09, 2015
Buy some new fuel line then put the line in from the motor side into the tank and feed up and through the opening on the tank. Then you can put on a new filter with a tiny clamp then put it back into the tank making sure the filter is resting on the bottom.
You need to adjust your idle screws. Start at 1 and a half turns out for High and Low then go from there.
you are getting a vapor lock, empty all the fuel, replace the filter and refill to the top.
Husqvarna 128 LD... | Answered on Aug 04, 2014
Husqvarna 128 LD Weedeater Logo
60 questions posted
Top Husqvarna Garden Experts
Marvin
Marvin
dannydoesita
Wayne McNeil
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
husqvarna weed eater starts but blows
  • Garden
