SOURCE: AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
SOURCE: The ribbed drain hose on
These drain hoses are universal types except that the connectors may differ. The different types of these hose - flexible ribbed- are found in almost all the stores that cater to pneumatic products.
Also you can source the original type from any dishwater/washing machine spares parts stores.
The hose can be removed after releasing the holding clamps and releasing the hose-- pull out .
Since these hoses are slightly flexible they are pushed into the drain ports and clamped.
you can get a good picture of this if the washer is moved forward.
Also take the hose along so that the store will recognize the product and make it easier.
In most cases the hoses are cheaper if they are sourced from the tubing shops than from the dishwasher spares store.
