20 Most Recent AEG 24 in. Favorit 60870M Free-standing Dishwasher Questions & Answers
If the END or DRYING indicator on the programme progress display is flashing, you can probably rectify the fault yourself.
After rectifying an END or DRYING fault, press the button for the wash programme that has been started.
The wash programme continues. If the fault is displayed again, than check water leakage in the battom of dishwasher.
Malfunction: END and DRYING on the programme progress display are flashing simultaneously.
Possible causes: The leak prevention system has been triggered.
Remedy: Try to find and repair water leakage otherwise close the tap and call customer service.
Dado
AEG 24 in.... | Answered on Nov 04, 2015
I think it is best to connect power cable directly to the interference filter where is normally connected.
The interference filter is connected in the terminal board parallel to the mains feed. See below pictures:
24034004-fvdtzpxoyys0i2rs1v4qjxt5-4-0.jpg 24034004-fvdtzpxoyys0i2rs1v4qjxt5-4-1.jpg
Dado
Problem with inlet water.
Could be: water tap closed, pressure switch....etc
Dado
AEG 24 in.... | Answered on Jul 06, 2015
Could be: faulty power board (completly or only relay for heating element), faulty wiring between heating element and power board, faulty heating element (interruption, short circuit or current leakage,on some heaters faulty thermal protection).
Depending on the model, the display shows the i60 fault code or the LED end of the program will flash 6 times (only model without display).
Dado
AEG 24 in.... | Answered on Jun 09, 2015
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
AEG 24 in.... | Answered on Jan 04, 2015
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Matthew, in most cases when a circuit board repeats the same action over and over, there was a short and loss of communication with associated controllers. Obviously you have power to the control unit, so that means the instructions from the controller to the solenoids is lacking. You are correct in assuming the board needs replacement, however you must determine is the cost for replacement is worth the time and effort. An old machine means one repair after the other. If its relatively new; then it may be worth it.
AEG 24 in.... | Answered on Mar 10, 2014
i have lost my manual can u tell me wat the 3 symbols mean please
AEG 24 in.... | Answered on Jan 02, 2012
Hello there and thank you for choosing fixya
This is a very common problem with these units
The problem is that the cycle timer goes wacky on these machines fairly easy this can be due to the water not being hot enough entering the machine 140-160 f. if it is not at that temp the machine will
not wash like it should also these timers will just simply fail so i would first check the water pressure and temp and ensure it is good then check all of the filters and then i would contact you local appliance dealer and see if they can test the timer for you this is normally tested for continuity to see if it is bad ok if it is replace it further more if too much detergent is used it will clog up the system and this can give a bad result too so ensure there is not detergent clogging it up any where ok
Hope this helps you out
Best regards Mike
AEG 24 in.... | Answered on Jun 11, 2011
i would need a full model number to assist you further which is normally located on the side of the door perimeter or door landing perimeter when the door is opened..Email to: applianceservice24_7@yahoo.com thank you .......... daniel
AEG 24 in.... | Answered on Apr 22, 2011
It is probably not oil. Its from a rubber gasket that is slowly dissolving inside. It has to be replaced before the machine will have a leakage. I´ve had the same problem myself. Using high-quality detergent, (usually tablets) that is less aggressive to rubber will extend the lifespan of the gasket in the future.
AEG 24 in.... | Answered on Apr 15, 2011
its probably anti flood error and u might have a small leak somwhere
AEG 24 in.... | Answered on Aug 11, 2010
AEG 24 in. Favorit 60870M Free-standing Dishwasher Logo
47 questions posted
Top AEG Dishwashers Experts
Paul Carew
Mike
Mark Brooker
Level 1 Expert
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
AEG Dishwashers
  • AEG Dishwashers
Most Popular Question
aeg favorit 60870 dishwasher not
  • Dishwashers
