20 Most Recent
AEG 24 in. Favorit 40630 Free-Standing Dishwasher Questions & Answers
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Aeg dishwasher will not drain
The washer has a drain motor in line with the outlet pipe. The motor must turn when in outlet mode. This motor has an impeler that turns at high speed to pump out water in the outlet mode. The motor could be faulty or the lelectrical push on connectors to the motor loose. One can remove the motor and coonect it directly to the mains voltage for a few seconds to check if it spins (also make sure that nothing is blocking the impeler from spinning).
AEG 40630 -top and middle lghit are flashing
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
Upper basket spray arm
Have you checked that the cover for the water inlet at the top where it connects to the spray arm is attached? It could have worked loose. Just re-attach and your spray arm should "miraculously" start rotating again!!
AEG FAVORIT 35085 Vi dishwasher Beeps 5 times and stops
If your AEG FAVORIT 35085 Vi dishwasher beeps five times and stops halfway through a wash cycle, there could be a few potential causes for this issue. One possibility is that there is a problem with the water supply, such as a clogged or partially blocked inlet valve. Another potential issue could be related to the drainage system, such as a clogged filter or a malfunctioning drain pump. It's also worth checking if the dishwasher's spray arms are spinning freely and not obstructed by any debris. If the problem persists, it is recommended to consult the dishwasher's manual or contact AEG's customer support for further assistance. They can provide specific troubleshooting steps and guidance based on your dishwasher's model and any error codes that may be displayed.
The anti flood device has activated on my AEG dishwasher????
If the anti-flood device has activated on your AEG dishwasher, it means that water has leaked into the base of the dishwasher and triggered the safety device. The anti-flood device is designed to prevent water damage to your home and shut off the water supply to the dishwasher.
To resolve this issue, you will need to locate the source of the leak and fix it. Here are the steps you can take:
- Turn off the dishwasher and unplug it from the power outlet.
- Disconnect the dishwasher from the water supply and move it away from the wall.
- Check the inlet hose, outlet hose, and drainage hose for any cracks, damage, or loose connections. Tighten any loose connections and replace any damaged hoses.
- Check the dishwasher door and gasket for any damage or debris that may prevent it from closing properly.
- Check the dishwasher's interior for any leaks, such as a cracked spray arm or a damaged pump.
- Once you have fixed the leak, you can reset the anti-flood device by tilting the dishwasher to one side to allow the water to drain out of the base. Then, level the dishwasher and plug it back in.
If you are unable to identify or fix the leak, it is recommended to call a professional technician for assistance.
My AEG F86070VI dishwasher wont switch on
Did you check the emergency shut off switch? Almost all under the counter dishwashers have a wall switch to interrupt the power. The problem is it can be shut of on accident.
