20 Most Recent AEG 24 in. Favorit 60830 Free-standing Dishwasher Questions & Answers
you have to mopp up any water in the base of the machine. this can be caused by a leak . a sagging pressure pipe to the pressure switch can do it as well. you can tie it up to stop the sag. its at the front behind the plinth area.
AEG 24 in.... | Answered on Mar 28, 2017
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
AEG 24 in.... | Answered on Jan 19, 2010
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified..
AEG 24 in.... | Answered on Jan 17, 2010
Just pulled machine right out, tipped it over on the side, couldn't see anything obvious or a way "in", so re-positioned it - switched on - error message gone and all working fine !!?!
AEG 24 in.... | Answered on Feb 18, 2009
We had this a while back on ours. For us it meant that the flood prevention system had kicked in. I took the metal panel at the bottom at the front off and sucked out water with a syringe until it started working again. We think the problem was that something was blocked with grease so ran a hot cycle with a Finish cleaning cartridge in.
AEG Dishwashers | Answered on May 09, 2019
Google or request from manufacturer
AEG Dishwashers | Answered on Mar 05, 2019
I guess you got the alarm AL 6 on your display what means failure to drain. A control procedure has been added to all the final drain phases in order to check the status of the pressure switch. The contact must be open in the "empty" position in order to ensure that the cycle is performed correctly. If the contact is closed, the drain phase is repeated. At the end of the second drain phase, if the pressure switch contact remains closed, "AL" alarm condition is generated.
Could be following:
  • Domestic drain circuit not suitable (obstructed / blocked)
  • Drain pump jammed
  • Pressure switch faulty
  • Sump - pressure switch tube obstructed
  • Filters / drain hose obstructed
  • Relay or Triac faulty
Down under is from AEG Favorit 86460 user manual, page 30 :
...a flashing fault code appears
an audible signal informs you that an alarm has been activated, in the display appears one of the following flashing alarms: AL1 - AL2 - AL3 - AL4 - AL5 - AL6 - AL7, AL8 and the indicator light of the phase under way is flashing. They are indicative of a fault in the dishwasher that you can probably rectify yourself.
- press the On/Off push button to switch the dishwasher off
- open the door and carry out the following suggested corrective actions.untitled-wdmylhxvjmokugi3zifm2oyn-2-0.jpg
Dado
AEG Dishwashers | Answered on Jan 12, 2019
check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
AEG Dishwashers | Answered on Nov 27, 2018
AEG 24 in. Favorit 60830 Free-standing Dishwasher Logo
24 questions posted
Top AEG Dishwashers Experts
Paul Carew
Mike
Mark Brooker
Level 1 Expert
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
AEG Dishwashers
  • AEG Dishwashers
Most Popular Question
recurring 30 fault aeg dishwasher
  • Dishwashers
