20 Most Recent AEG Favorit 50500 Built-in Dishwasher Questions & Answers
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
AEG Favorit... | Answered on Jun 13, 2018
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
AEG Favorit... | Answered on Jul 08, 2016
u just try to delete
AEG Favorit... | Answered on Dec 20, 2013
I suffer the same issue it was only fixed by upgrading the washing tablets used
AEG Favorit... | Answered on Nov 16, 2012
sounds like the heating element has gone out
AEG Favorit... | Answered on Sep 20, 2011
Hi
The polystyrene float you are referring is the water inlet valve where water hose is connected to. You would need to check & replace the water inlet valve. Hope this helps... Please post back if you need more information.
Daniel
AEG Favorit... | Answered on May 20, 2011
First make sure that the float valve is not stuck up with some thing under it, Its the little plastic cap at the left front bottom of dishwasher and should move freely by hand up and down and you should hear a slight click.
AEG Favorit... | Answered on May 16, 2011
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
AEG Favorit... | Answered on Apr 26, 2011
Pull old seal out and push new seal in
AEG Favorit... | Answered on Mar 28, 2009
could be due to goalpost seal in poor condition or door latch needs adjusting
AEG Favorit... | Answered on May 09, 2007
We had this a while back on ours. For us it meant that the flood prevention system had kicked in. I took the metal panel at the bottom at the front off and sucked out water with a syringe until it started working again. We think the problem was that something was blocked with grease so ran a hot cycle with a Finish cleaning cartridge in.
AEG Dishwashers | Answered on May 09, 2019
AEG Favorit 50500 Built-in Dishwasher Logo
56 questions posted
Top AEG Dishwashers Experts
Paul Carew
Mike
Mark Brooker
Level 1 Expert
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
AEG Dishwashers
  • AEG Dishwashers
Most Popular Question
glass glass cups or plates come out
  • Dishwashers
