Which Linksys model of router? What cable service? What did they say needed to be configured?
https://www.linksys.com/no/support-article?articleNum=142912
SOURCE: How To Set Up PPPoE DSL Connections with a Linksys Router
This article describes how to manually configure a Linksys Router for broadband DSL that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication. For automatic configuration options, please try: 1. Linksys Easy Connect (see Answer ID 1650 for more information), or 2. The Linksys Setup Wizard CD-ROM software that came with your Linksys Router. Simply insert this CD-ROM into an online computer before connecting your Linksys Router, and the Wizard will provide step-by-step instructions on how to install and configure your router. If you are unable to set up your Linksys Router by using one of the above options, use the steps below to manually configure your router. NOTE: It is recommended that you print this article for offline reference. STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address ([email protected]). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address ([email protected]). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to
SOURCE: configure router
You haven't specified the version no of the router. If you would turn the router upside down, you can see the model no and the version no right next to it. Although, the configuration of all the versions would be the same, you still need to make sure it has the latest firmware if its a older version. Here is what we need to do... 1. Connect the modem to the Internet port of the router 2. Connect the desktop to the port 4 of the router 3. With the router turned on, push the reset button on the router and hold it for 20-30 seconds. 4. Power Cycle: Unplug the power from the router and the modem. Wait 30 seconds and turn on the modem first. Wait 1-2 minutes till the ligts on the modem are steady. Turn on the router. 5. Wait till the lights on the router are all turned on (takes around 1 minute) 6. On the desktop, open your web browser 7. In the address bar, type 192.168.1.1 8. It must prompt you for a username and password 9. Skip the username and type the password - 'admin' 10. That must bring up the setup page of the router 11. There is tab on the top right corner - 'Status'. Click on that 12. In the status tab, you must see the internet ip address - 192.168.1.64, which is the ip address provided by the modem 13. Go back to the setup tab 14. In the setup tab, you would see the local ip address = 192.168.1.1 15. Change it to 192.168.2.1 16. Click on Save Settings (scroll down to the lower end of the screen to see this option) 17. Wait for 30 seconds and close the web browser 18. Power Cycle again (refer step 4) 19. Now internet must work on the desktop 20. By default, the network name (SSID) of the linksys router is - 'linksys' 21. You can go to the laptop(i assume it has windows xp), and try to connect to this network by - right click on the wireless icon in the system tray (on the right bottom corner of the screen) and click on 'view available wireless networks' 22. You must see 'linksys' as one of the available wireless networks 23. Try connecting to it and you laptop must work Those steps are generalised and you might get stuck in exceptional cases. If this does not work, please initiate a chat session with any of the experts, if this does not work, because this may require some advanced troubleshooting which would not be possible using those short messages. Good Luck
SOURCE: Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
SOURCE: Linksys Wireless Router Model No. WRTU54G-TM Router Configuration
Open a browser
type 192.168.1.1 in hte address line, press enter
you should get a prompt for a username/password
Leave username blank
Password admin
this should get you to the firmware configuration.
If you can't access the router, press and hold the reset button on the back for 5 seconds with the point of a pen, then try again.
Hold the reset pin on the back of the router for 30 seconds to reset the router configuration.
You might have to try a few times.
See if your computer connects to the default LINKSYS ssid.
If you are able to connect, then it was a configuration issue. Or some corruption of the router's firmware.
Connect your computer to the router using a network cable, and go to http://192.168.1.1 username: (nothing) password: admin
Download the latest firmware for the router, and configure it for better security. Do the configuration step by step, to see which actual part of the securing stops communications.
A good security measure would be the following, test wireless connection after each change (you would need to configure your computer wireless settings accordingly. You have to be connected by a wire while doing the changes or you might lock yourself out):
1. change the router password
2. Turn off SSID broadcasting
3. Change the ssid from LINKSYS to something only you would know, like BwRiAfNiDY (it is not case sensitive). Write down the name as you will need it to configure the laptop wireless.
4. Setup personal WPA TKIP / AES encryption
If you are far away from the router when using it wirelessly, and it starts losing connectivity, drop it's speed to a lower setting.
