Try this link might help you sort it out. vacuum is stuck in the upright position Google Search
SOURCE: No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
SOURCE: dyson 18 losing suction
Check the HEPA filter if it has one. This bit of foam gets clogged over time and significantly reduces the suction especially if you've been vacuuming a lot of very dusty areas i.e. dust from building work etc. Just wash the filter with lots of water and leave to dry before reinserting.
SOURCE: dyson 28 handle is stuck in the locked and upright
how do you remove the air duct (plastic sliding piece) that is making the vacuum stay in locked upright p[position?
SOURCE: Dyson DC28 Air Muscle Vacuum that is stuck in upright position
This turns out to be an easy fix.
First, get some graphite lube.
Lay the vac on it's 'face'.
1) On the underside of the vacuum, there is a 1/2" wide 'groove" in the motor housing, that runs up the centerline of the machine. Follow this groove from the front of the machine towards the back. As you follow it 'up' into the machine, the groove will 'end'. Just past this point there will be a small black plastic piece with little 'ears' that is resting in another groove that continues just past the point where the first groove ended. This is the upright position lock that isn't releasing. (I've painted the 'ears' red in the attached photo)
2) Using a screwdriver, or butter knife, etc, gently lift this piece out of the groove. The vacuum head should now easily tilt down like it should.
3) Flip the vacuum over onto it's 'back' and you will be able to see the grooves, now visible on the front of the lower head. Apply the graphite to the smaller (upper) groove and try working the unit in and out of the upright position several times to work the graphite into the locking mechanism
