The only way I can start is to help rotate the flywheel or jump it with my truck. Almost like too much compression or not enough power in battery.
SOURCE: 95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
SOURCE: 93 buick lesabre 3.8 liter starter replaced,new one just clicks
Given the steps you have taken, only one of two things this can be is a resistive connection between the battery and the starter solenoid terminal. Or the battery itself has a bad internal connection. Bear in mind: you cannot crank the engine through the average set of jumper cables unless the battery in the dead vehicle will hold and deliver a good charge. Jumper cables are not really intended to start the car, they are for boosting the good, but low battery in the car being jumped.
SOURCE: I HAVE A 1995 ISUZU
Could be one of two things.
1. Your starter motor is no good.
2. If you turn on your lights and try to start the car and they dim to almost black, then you need to check the battery connections.
SOURCE: starter not catching flywheel
the starter is either not engaging or the bendix is shot. Bendix is the gear assembly that slides on the starter shaft. it should spin free in one direction and turn the starter in the other. and slide freely on the splines (in/out)
