F14 Misconnected keyboard cable. 1) Verify connection between display board and touch panel (2 ribbon cables). Make sure the cables are well connected at both ends. 2) If the cables are good, replace the touch panel. 3) If the problem persists, replace the display board....
i found this on the internet plus try this link to the manual.....http://manuals.electroluxusa.com/prodinfo_pdf/lassomption/318127078.pdf....or this link.... http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Range-Parts/Repair-Maintenance/Questions-Answers/f14-what-does-it-mean-EI30ES55LWA-Electr/Model-EI30ES55LWA/1412/0124160/386214?modelNumber=EI30ES55LWA .with this link scroll down the page and were you see the word (click here) that will take you to the manual as well.
F14 misconnected keyboard cable. 1) verify connection between display board and touch panel (2 ribbon electrical cables).make sure the cables are completely seated into the connection point both ends. If the cables are connections check ok then replace the touch panel. If the problem persists still occurs replace the complete display board
Thanks for your inquiry, Adrian Gonzalez!
From the information you have provided your Electrolux range is displaying an error code of "F23". "F23" stands for communication failure between the EOC (Electronic Oven Control) and ESEC (Electronic Surface Element Control) I would attempt to perform a reset on your range and you could do that by disconnecting the power from the range for ten minutes. If you continue to experience a problem with the error code it could be an issue with the EOC or VSC (Variable Speed Control) board. Hope this helps. -Matt
Thank you for your inquiry, friend!
I understand that you are looking for the meaning of "E15" on your Electrolux range. "E15" stands for ESEC self-test failed, which could either mean and issue within your UIB (User Interface Board) or relay board. I would recommend having a professional come out to diagnose and repair your appliance. Best of luck. -Matt
