20 Most Recent
Electrolux EW30GS65GB Gas Range Questions & Answers
Electrolux glass cook top model PLEC30SS980CB says ER on one burner.
When an Electrolux glass cooktop displays the "ER" error code on one burner, it typically indicates an issue with that specific burner. Here are a few troubleshooting steps you can follow to try and fix the problem:
1. Turn off the power: Start by turning off the power to the cooktop at the circuit breaker. This ensures your safety while working on the appliance.
2. Check for debris or obstructions: Inspect the affected burner for any debris, food residue, or obstructions. Clean the burner thoroughly with a soft cloth or sponge, ensuring there is no buildup that could be causing the error.
3. Reset the cooktop: After cleaning, reset the cooktop by turning the power back on at the circuit breaker. This may clear the error code and allow the burner to function properly again.
4. Check the wiring: If the error persists, there might be a wiring issue. In this case, it is recommended to contact a professional technician or the Electrolux customer service for assistance. Working with electrical components can be dangerous, so it's best to have a qualified professional handle the repair.
Electrolux customer service can provide further guidance and troubleshooting steps specific to your model if needed.
Electrolux range touch pad for model EW30ES6CGS4 willl not shut glass burner
If the Electrolux range touch pad for model EW30ES6CGS4 is not shutting off the glass burner even when it shows that it is off, there are a few troubleshooting steps you can try:
- Check for any physical damage: Inspect the touch pad and the burner area for any visible damage, such as cracks or signs of overheating. If you notice any damage, it may indicate a need for repair or replacement of the affected parts.
- Power cycle the range: Turn off the range by disconnecting it from the power source or by turning off the breaker for a few minutes. Afterward, reconnect the power or turn the breaker back on and see if the touch pad responds correctly.
- Check for error codes: Some range models have error code displays that can provide information about specific issues. Refer to the user manual or manufacturer's website for instructions on how to interpret error codes, if applicable. This may help identify the underlying problem.
- Perform a factory reset: Look for instructions in the user manual on how to perform a factory reset for your specific range model. This can sometimes resolve software glitches or settings issues that may be affecting the touch pad's functionality.
- Contact customer support: If the above steps do not resolve the issue, it is advisable to contact Electrolux customer support or schedule a service appointment with a qualified technician. They will have the expertise to diagnose the problem accurately and recommend appropriate solutions or repairs.
When reaching out to customer support or a technician, provide them with specific details about the issue, the model number (EW30ES6CGS4), and any error codes or messages displayed on the touch pad. This information will assist them in providing you with the most effective support or service.
How to fix an error E 15 code on electrolux induction range
Thank you for your inquiry, Carol!
From what you have described your Electrolux range is displaying an error code of E15. I see you have reset your breaker and continue to receive the error code. The error code E15 means that your ESEC (Electronic Surface Element Control) test failed this could be a problem with your relay board or UIB (User Interface Board). When you reset your breaker did you leave it off for at least ten minutes? That is the best way to reset your range. You may need to seek assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Why do I get E 21 message on my Electrolux slide in range Model EW301S6CjSc which has frozen the stove top
Thank you for your post, Sandra Gee!
Based off the information you have provided an "E21" error code is displaying on your Electrolux range. Typically, an "E21" stands for a communication failure between the EOC (Electronic Oven Control) and the ESEC (Electronic Surface Element Control). I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. The best way to disconnect power is to flip the household circuit breaker. If you continue to have an issue with an "E21" error code I would have a professional technician perform a diagnosis on your range to help repair it properly. Hope this is helpful. -Matt
How do I troubleshoot E21 and E39 Codes?
I appreciate your inquiry, Bill Payer!
I understand that your Electrolux range is displaying error codes "E21" and "E39" and you are waiting for a part to become available to change. Based off the error codes "E21" stands for key sensor for cook place two which means a potential issue with the left board. "E39" stands for incorrect configuration. To configure your cooktop you would need to press and hold the "Warm" key, then press right front "Power" key until it beeps. Then press left front key and the configuration should start. If that does not help your situation I would suggest having a professional out for proper diagnosis. This will help to avoid any unnecessary part purchases. Best of luck! -Matt
Model EW30ES65GSA. What does error E11 indicate?
According to the service manual, E11 stands for shorted keypad.This can be caused by holding down a key for a short period of time. Here's what it is and what you can do.Please refer to the image for your reference. If the error code appears again after trying this maybe it could be an issue with your EOC ( Electric Oven Control). I would recommend to have a professional check your unit for proper diagnosis and to replace defective parts. Thank you.
Want to perform a clean cycle. Why do I keep getting a message to remove racks?
There is a sensor that detects the rails being in their slot, the switch allows the cleaning cycle to initiate. The temps of the cleaning cycle are too high for the racks and rails. I was surprised to find this. Since then, acquired alien technology has enabled engineers to develop high temp rails/ racks, or lower cleaning temps. It seems the newer ovens have fewer rail / self clean faults.
Error code F5 Electrolux Range
It can be one of several fixes depending on the exact model. First reset the display either at the breaker panel, unplug it, or on the display itself using the - and + (depressing at the same time for several seconds) if equipped. On some models it can also be a problem with the latching mechanism and cleaning may be all it needs.
What does F 14 mean on electrolux stove?
f14 misconnected keyboard cable. 1) verify connection between display board and touch panel (2 ribbon electrical cables).make sure the cables are completely seated into the connection point
both ends. If the cables are connections check ok then replace the touch panel. If the problem persists still occurs replace the complete display board
My Electrolux 30” induction slide-in range, Model # EW301S6CJSB, is locked and won’t unlock. Have tried unplugging it, all combinations of hold this and that, as read on previous entries, nothing!
Usually all you have to do is hold your finger on the icon until it either locks or unlocks. Otherwise contact Electrolux:
USA
1.800.944.9044
Electrolux Home Products, Inc.,
10200 David Taylor Drive
Charlotte, NC 28262
Canada
1-800-265-8352
Electrolux Canada Corp.
5855 Terry Fox Way
Mississauga, Ontario, Canada L5V 3E4
F11 error code on electrolux range. How do I fix the issue
An "F11" typically stands for a shorted keypad. You can reset your appliance by unplugging it or disconnecting power for ten minutes. If you perform this step and continue to receive an "F11" it could be an issue within your EOC (Electronic Oven Control) and I would recommend having a professional come out to properly diagnose your range
