I tried everything there is no paper jam i tried turning it off and on i reset it nothing is working.
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
SOURCE: canon pixma mp460 code error 6000
Solutions for error 6000
Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1.
Press ON/OFF switch to reset the multifunction device
2.
Removing paper jams MP450 / MP460
3.
The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
SOURCE: canon mx310 error code 6000
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing **** disk film or the printer's logic board.
SOURCE: canon pixma ip1980 service error 6000.. it flashes
you need to open the printer. it has sensors around it. the one that you need to check is in the left side when you are facing the printer. the one that is sensing the graduated circular part. Remove the left cover on the side. then remove the sensor with a philip screw driver and clean it. then place it back and turn your printer on. I hope to be of help to you. Let me know if this works. I did it on mine.
CAUTIONSee Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
CAUTIONCanon PIXMA MX922
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
