When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair.
Cause
1. Is there a securing material for the holder inside the printer?
Summary
There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder.
See Also
Cause
Summary
[ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again.
See Also
Cause
2. Is there a jammed paper or foreign material inside the printer?
Summary
Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
- If there is a jammed paper or foreign material inside the printer, remove them.
See Also
Cause
Summary
[ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also
Cause
3. Is the ink tank properly installed?
Summary
If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position.
See Also
Cause
Summary
[ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON.
See Also
Cause
Summary
[ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
