SOURCE: belkin wireless g problem
First, you will need to restore the settings on your router, then get your laptop onto the network.
SOURCE: Macbook loses wireless internet connection
Hi 8233 is a good choice for a router
Here's your solution
1. These steps are to be performed strictly from a computer which is wired.
2.Even if you are using your mac book turn of the airport and connect it via a cable.
3. Open your router setup page by typing in 192.168.2.1 on your browser tab or typing i http://192.168.2.1 in the run window
4.An rsp will open and on the top right hand corner of the screen it will say Internet status:: connected
5.On the left hand side change you"ll see channell under wireless
6. Select it and change it to 6 or 11 for best signal strength
7.Now to the most important segment 8233 has a piculiar issue with its extra strong security
8.On the left hand side under wireless you"ll will see an option called wi-fi protected setup
9.Select it and turn it off reboot router and wow the problem should definately be resolved .
Then turn on airport and go wireless along with your wife.
10. You will still be secure with your data through security option on your router (wep or wpa )whatever you use .
Thank you and just let me know if it worked or not
SOURCE: New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
SOURCE: wireless light flashes red when my laptop tries to
if your using lenovo and is an Ideapad Y series or a G series Laptop look for the program called lenovo readycom in the control panel add remove programs if you have XP and if vista go to control panel and look for programs and features this goes the same with win7 just uninstall Lenovo Readycom 4.0 or 5.0 and as well look for a program called network magic if that program is present then uninstall this as well then restart your laptop, try connecting again ^_^ happy surfing ..
SOURCE: belkin n300 has a red light and willl not connect to the internet
Unplug the router and ISP modem. Connect and cycle the modem if there is a reset. If not wait a few minutes and reconnect everything.
The Belkin also has a reset, but holding it clears all custom settings. While a quick push is a restart.
Hi gordon wylie, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
what is the operating system of the computer ?
If windows 8 the router may need to be logged into and the firmware should upgrade to work with later operating systems.
You may find this is the cause of your grief
