20 Most Recent Belkin Surf N300 Wireless N Router Questions & Answers
How do I setup a Belkin N300 router without CD
Power it up and use an ethernet cable to connect to the router. Then you should be able to login to the router UI to set up your preferences.
12/19/2018 7:20:44 AM • Belkin Surf N300... • Answered on Dec 19, 2018
I have hooked up mthe belkin surf N300 wireless N
Is the router showing you the correct network when you view the available wireless networks?
11/4/2017 6:30:46 PM • Belkin Surf N300... • Answered on Nov 04, 2017
2answers
I need to install n300 without cd
GO HERE AND FOLLOW THE INSTRUCTIONS
6/2/2017 8:41:42 AM • Belkin Surf N300... • Answered on Jun 02, 2017
2answers
My belkin has to be restarted each time using wireless
When the "wireless adapter" was installed in your laptop, a so-called wireless manager similar with the wireless zero configuration of winxp was installed as well.And the news is, everytime you boot up your system, it will automatically enable the wireless manager that was installed with the adapter. That's why you have to go to services.msc all the time so that you can use the wireless zero configuration.you need to troubleshoot the adapter ..and restart your pc..**If you need any kind of technical assistance you can contact support cell at here
4/3/2017 9:40:30 AM • Belkin Surf N300... • Answered on Apr 03, 2017
My mac laptop can't connect to belkin n300 router wirelessly
There is a small piece of paper underneath the router with original passwords, and the default was WPA security.Hold the reset in the back till it cycles to remove any custom settings.
12/20/2016 11:29:09 AM • Belkin Surf N300... • Answered on Dec 20, 2016
After a power outage must we reset the extender.
No. when the power restores the settings should work automatically.
10/2/2016 12:24:35 PM • Belkin Surf N300... • Answered on Oct 02, 2016
Is there a fix to wii error code 50300 ?
The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered. It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings. While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option. If the problem persists, try our general troubleshooting for tips. If you are still getting this error code, please call 1-800-255-3700 for further assistance. For more help visit cbrtechsolutions
11/5/2015 7:22:27 PM • Belkin Surf N300... • Answered on Nov 05, 2015
What is the security key of router n300
read this http://www.belkin.com/networking/manual/MAN_F7D6301_v1_8820-00697_Surf_N300_N_Router.pdf LOST ROUTER LOGIN PASSWORD If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usually be found online at the router manufacturers site. There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware resets and clears out the old information. If you are trying to get into someone else's router illegally there is no way to find out their login password. For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
4/24/2015 10:52:16 PM • Belkin Surf N300... • Answered on Apr 24, 2015
2answers
The Box claims there is a Guest Access. I find no reference or settings within the Router Set up for this activity. How do I set up Guest Access?
Hi Norman,For guest access:You can allow guests to use your Internet connection without joining your personal network. . The network name and password for the guest network is located on the network information card found under the foot of your Router .A person using your guest network will be able to join without a password, but will be shown a login page when they attempt to surf the Web.. They will need to enter the guest password into this page to continue.Hope this helps!Please Rate if it did!Thanks,Gary
2/8/2015 3:03:50 AM • Belkin Surf N300... • Answered on Feb 08, 2015
I am trying to get wif on my samsung galaxy it tells me get guest password can you help
You would need to refer to your Belkin's instruction manual for how to set up WiFi on it. The password for any WiFi hot spot is unique to that hot spot so there is no general 'guest' password per se - it depends on how you setup the WiFi router. WiFi routers also have a web-based interface where you can open a browser from a connected PC and manage the device. Again, the device's instruction manual will tell you how to do this. If the router was supplied by your internet service provider you should be able to call them for help.
1/27/2015 11:19:31 PM • Belkin Surf N300... • Answered on Jan 27, 2015
0answers
Belkin Surf N300 Amber Light Flashing
Hi, did you try out the procedure presented on page 16 of this manual? http://www.belkin.com/networking/manual/MAN_F7D6301_v1_8820-00697_Surf_N300_N_Router.pdf
3/20/2014 10:31:40 AM • Belkin Surf N300... • Answered on Mar 20, 2014
0answers
0answers
Belkin Surf N300 Wireless N Router Logo
137 questions posted
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
setup belkin n300 router without cd
  • Computers & Internet
