Cassette sensor switch inside the machine body. Remove cassette outside and check machine body bottom where cassette is installed. Switch Has been misalignment by unfortunately. Align this two Switch Sensor Then again install cassette. Hope its working.....
That's right ... in my case, I noticed that he was detached and moving freely. My advice is to remove the cassette and lift the entire printer (it is not screwed to the base), place it on the ground on one side and in this way you will be able to easily access the sensor from a small hole in the metal bottom.
Make sure you load paper either of the trays, (ByPass) or Drawer 1.
Select the same tray in print set up on your computer.
select same paper/tray on ur printer screen.
this worked for me.
To fix the error:
- You select setting
- Device Settings
- Plain Paper Feed Settings
- Set up on Rear Tray instead of cassette
SOURCE: need user manual for image runner 5000
http://www.fixya.com/support/p189647-canon_imagerunner_5000_copier/manual-18713 here ya go, please give me good rating as far as being able to help you. Take care. :-)
SOURCE: I have a Canon Image runner 1023. when I print i
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
SOURCE: in A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
SOURCE: Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
SOURCE: My canon ir 2018 is asking me to load correct
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
