Here is how i fixed my Dyson dc44 not charging, it turned out to be easy, but i went through checking everything else on the way to find a simple fault and fix
It your Dyson no longer charging then it is most likely the battery and the charger needs replacing. Replacing these parts normally fixes this issue.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
If you have a DC voltmeter and can see the contacts in the charger, you may be able to see it the charger has a output. But with the newer electronics for battery charging, the battery may need to be in the charger to get a reading. My guess is you do have a bad charger.
If your DC44 won't run when you hold the trigger down, but displays a solid green light, this indicates that the battery is out of power. If this continues after you've connected the machine to the charger cord for at least 5.5 hours to recharge fully, it suggests that there could be a fault with the charger, battery or main body.
When you have your DC44 to hand I would encourage to you call the Dyson Customer Helpline so our experts can talk you through some simple diagnostic checks. Once we're clear which part is affected, we can confirm if a replacement is covered under your Dyson warranty.
You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
I'm sorry to hear about the difficulty you've experienced with your DC44 Animal. In order to diagnose the cause of the issue and determine the correct resolution, we'd need to take you through some quick troubleshooting checks when you have your machine to hand.
When you have a moment, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we can also confirm if this is covered under our 2-year parts and labour guarantee.
I'm sorry to hear your DC44 Animal doesn't seem to be working correctly. If the green LED indicator on the machine lights up, but the machine itself doesn't run, this suggests the battery is flat. It could mean that it's not recharging correctly when connected to the docking station.
It would be worth temporarily disconnecting and removing the charger cord from the docking station and plugging it directly into the machine - the machine should recharge fully within 3.5 hours. If the machine then works as normal the charger cord may not have been corrected fitted to the docking station.
If you'd like further advice from our experts after you've given this a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
The issues with your DC44 Animal sound unusual, and we'd like to take some further details. If a replacement part is needed, we can also confirm if your machine is within our 2-year warranty period.
When your machine is fully charged and easily to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to run you through some quick diagnostic checks to help determine the best course of action.
I'm sorry to hear you're having difficulty recharging your DC44 Animal. It should charge from flat within 5.5 hours when connected to the charger assembly, or placed in the docking station, as shown in the video above.
The charge light will turn off once the battery is fully charged. If it seems to be shutting off prematurely, we would need to take you through some quick diagnostic checks when you have the machine to hand. This will help us confirm what may be needed to resolve the issue.
Please give the Dyson customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA), to speak directly with our team of experts.
