2002 Mercedes-Benz S-Class Logo
Posted on Jul 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 Mercedes Benz S600 Torque on Upper Intake
What is the spec on torque for the bolts on the upper intake of a 2002 Mercedes S600 (V12)?
  • Anonymous Mar 19, 2014
    adjust time
SPEEDY CAR WORK SHOP
Level 2:
  • Mercedes-Benz Expert 489 Answers
  • Posted on Aug 15, 2009
Level 2:
Answers
489
Questions
Helped
160070
Points
671
That is the intake manifold and there are 3 stages for it , I will list for you the 3 stages :
1st stage M6 Nm 8 M8 Nm 20
2nd stage M6 Nm 8
3rd stage M6 90 degree
Hope it helps
2answers
What are the torque specs and sequence for Mercedes Benz C300 V6.
limited info generic answer if looking for all specs then buy a repair manual multi sites online can download or hardcopy -
03 Dodge Intrepid intake manifold torque specs top & bottom is for 3.5 V6
Lower Intake:
  1. Use a skin coat of RTV silicone on both sides of the water passage ports (outer most holes) and put the new lower intake gaskets into place
  2. Hand tighten the 13mm head intake bolts and Torque the bolts , starting from the center and working your way out in a circular pattern
  3. Torque these bolts in a few small increments until they have reached 250 inch pounds of torque.
  4. Upper Intake Plenum:
  5. When installing the intake air plenum , be sure to catch the four center bolts and the two side bolts (stiffener brackets) before tightening , The center bolts should be torqued to 250 inch pounds .The fuel rail bolts should be torqued to 100 inch pounds
1helpful
Torque sequence 3400 engine upper intake
starting at the middle bolt and go directly across then criss cross the pattern like you would tightening wheel nuts, towards the outside(end) bolts. if this is a plastic upper intake the torque should be around 15ft lbs if its metal around 25ft lbs.
1helpful
Intake manifold torque specs.
It is criss cross from front to back around 15 foot pounds so snugging them with a ratchet should do the trick
10helpful
2answers
Need the torque specs for the upper intake bults on a 2002 chrysler sebring conv. 2.7L
Fig. Intake manifold bolt torque sequence 2.7L engine
Upper intake manifold with a new gasket on the lower intake manifold and torque the bolts, in sequence, to: 105 inch lbs. (12 Nm)
Hope helps (remember to rate this answer). Good job.
2helpful
Im looking for torque specs and bolt sequence for the upper intake on a 2002 diamante, 3.5
The intake is not a high torque part, it is usually just put down with normal ratchet tightness and alternating sequence of the bolts. You tighten stuff more than torque specs anyway by hand, you don't even know it. the only thing I have ever used my torque wrench on is the heads, and sometimes I don't even use it there. I always go back to check later anyway. Hope this helps.
11helpful
2answers
Need torque specs for 2000 chevy malibu 3.1 cyl heads & intake
(step 1 ) the torque specs for the heads are---1998 through 2001 are 37 foot lbs. ( step 2) rotate an additional 90-degrees (1/4 turn). intake manifold bolts ( lower ) step 1-- 62 in-lbs, step 2--115 in-lbs. intake manifold bolts/studs ( upper ) 18 ft-lbs. this is for the 3.1 v-6, have a good day!
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
