Sewing Machines Logo
Donna Iturreria Posted on Mar 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why doesn't it sew?
Hand wheel won't turn, I try to. Sew and all it does is hum.
R.A. Ellis
Level 3:
  • Baby Lock Master 12,731 Answers
  • Posted on Jun 01, 2016
R.A. Ellis
Baby Lock Master
Level 3:
Answers
12731
Questions
Helped
2619424
Points
59176
Resist the temptation to run the motor. If the motor is unable to operate the machine, it could damage the motor.
Take it for service.
salsewnso
Level 1:
  • Contributor 20 Answers
salsewnso
Contributor
Level 1:
Answers
20
Questions
0
Helped
4665
Points
46
Check to see if the bobbin case is in correctly. Jamming occurs when something isn't in machine properly. Try taking out the needle & manually turning the hand wheel slowly. It could be just a bent needle too.
How to turn safety lock off on nx-400
Initially, the "safety device has been activated" error is usually caused by a jammed thread or fabric.
2 possible causes
The upper thread has become tangled around the bobbin case,
The needle is bent and hitting the needle plate, so the machine stops.
To fix this error.
1, Unplug your machine,
2. Remove the needle ( I know it is in a down position and locked up) but you can be able to remove it.
3. After removing the needle, turn your hand wheel if still locked up or stiff. Remove your needle plate and remove all your threads both upper and lower.
4. Clean your bobbin area using a brush take a deep breath then blow.
5. After that, try to turn your hand wheel again, if the hand wheel moves freely, rethread your machine and replace your needle with a new one. Then try to sew a few stitches using a hand wheel (do not sew using a pedal) if the hand wheel creates stitches that is the time to sew using the pedal.
If the problem is still there, you possibly have broken gear that needs to be replaced
1helpful
My sewing machine has stopped working, it was working ok , just a bit noisier than usual but now the needle wont move at all, even if i try to turn the wheel by hand
the machine may need oiling, check in your sewing machine manual to see about oiling it, it's also possible that the machine could have a damaged or broken part inside,,
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Machine won't sew. Motor hums. Any ideas as to problem?
could be locked up or have a damaged part
the machine needs to be serviced
1helpful
Singer Stylist 513 - motor hums, won't sew
the machine needs to be check at a sewing machine shop
2answers
Motor is fine, but won't sew
since the machine has been setting for 20 years, it needs to be serviced
the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
My machine jammed up with some thread under the fabric but nothing by the bobbin. but the needle won't move it just hums when I try try to sew.
If you can't turn the handwheel, then there is thread jamed up in the hook. You can try to rock the handwheel back and forth to try to get the thread out. If you do get it free, try to sew with it. If it won't sew properly you might have a damaged position finger or it's out of time. You'll need to take it to a PFAFF dealer.
2answers
Singer 600 touch and sew
Hold the tail of the needle thread loosely.
Turn the hand wheel toward you (counter clockwise) and lowerthe needle into the hole in the plate.
Turn the hand wheel until the needle rises back up to it's highest position.
Gen
You will see a loop of thread wrapped around the upper thread.
Open the loop and find the free end of the bobbin thread.
Voila!
Now you can sew.
Top Baby Lock Sewing Machines Experts
vince
NOEL
NOEL
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
